Results 1 to 13 of 13
Thread: ---->Cylinder #1 not firing<----
    IA MEMBER jvillagran2000's Avatar
    EVERYWHERE!!!
    Default ---->Cylinder #1 not firing<----
    Well I payed someone to replace the headgasket on my Z6,the head was warped as well so it had to be machined.Well after all is said and done the motor does not overheat any more but cylinder #1 is not firing at all,I checked for spark and it's there.I'm sure I have fuel cause the other 3 cylinders are firing fine.I took the sparkplug out and it was soaked in oil.So I'm thinking that the valves are either bent or the seals went bad it was running fine before the procedure it just ran hot.What are your opinions?
    compression test it
    ^^^^ I got a good head if you need it lmk
    EVERYWHERE!!!
    well it turned out to be a mistake by the machine shop that milled the head cause it was warped.They milled it to much causing the valves not to open completely.
    Wheres the money?
    McDonough
    damn that suck!!!!
    to many projects not enough money
    well I got a head just lmk if you need it man
    EVERYWHERE!!!
    Have you been able to take the broken bolt off the cam shaft yet?
    No no need your cam is fine!
    JDM TYTE AnthonyF's Avatar
    What shop to inform others NOT to go there.
    Like I said, it's either DOVER heads, or be run over by a bus.
    -Ant.
    The Carbon Fibered R6
    I use dover myself!
    EVERYWHERE!!!
    -Ant.
    I'm pretty sure it was an isolated incident and they made it right.
    i go to dover also, havent screw me over yet. Been a customer for 10 yrs.
    ive used a bunch of places. most places dont mess up something as easy as a mill. atleast your corrected the issue.
