Results 1 to 1 of 1
Thread: Polk/Momo MMC650 6.5" Speakers w/ Crossovers
    Default Polk/Momo MMC650 6.5" Speakers w/ Crossovers
    These are not your typical run of the mill speakers. They are made from high quality materials, the cones are made of carbon fiber. These are basically like new, comes with 2 Speakers, 2 Speaker Grills, 2 Mounting Plates, 2 Crossovers, Mounting Hardware and Manuals. If you want that hardcore, high quality sound these are the speakers for you. Asking $90.00
    Specs:
    Driver Complement -
    Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
    Woven Carbon Fiber with rubber surround
    Tweeter 1 - 1" Diameter (2.54cm)
    Silk/Polymer composite dome
    Electrical -
    Overall Frequency Response 43Hz-25KHz
    Nominal Impedance 4 ohms
    Power Handling (continuous) 80 w
    Power Handling (peak) 180 w
    Efficiency 90 dB
    Install Dimensions -
    Full-range Mounting Depth
    Top Mount 2-7/16" (6.19cm)
    Bottom Mount 2-9/16" (6.51cm)
    Tweeter Mounting Surface Mount Height 1/2" (1.27cm)
    Driver Cut-out Diameter 5" (12.70cm)
    If any questions call or text me at 404-232-0788
