Thread: axle nut
    F.A.N.A.T.I.C. primespark22's Avatar
    Default axle nut
    ok so i was taking out the bolt that screws in with the cv axle in order to take out and change the axle,But the nut has stripped and i cant get it out so any ideas on how to get it out now?
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    WRX on Roids
    well your about to change the axle so don't worry about screwing it up. With that said cut the thing off. Take the wheel off the go to town on it.
    i was thiking bout that but all i got is grinder and there is not enough room to cut ill look at it again tomorrow.thanks tho
    torch, angle grinder, or a drumel is how i get them off when they are fubar.
    take it to a shop, its people like this that puts us real Mechanics out of bussiness because everyone thinks they are a mechanic, with that said.. With out the right tool you need it will be just about impossible to get it out
    Kudos to you for trying to do it yourself, and you have every right to learn how to work on your own car. Anyways, is there anything left to grip it with at all? i know it's a dumb solution, but have you tried some pb breaker, that could be part of your problem, and it can work wonders
    Quote Originally Posted by jakerd4892
    ive seen the problem hes having. and pb blaster isnt going to cut it.
    like i said nomo hondas, probably isnt. Just wasn't sure exactly how bad he said it was.
