Thread: 310cc's with SOHC Boost
    my momma's house
    Default 310cc's with SOHC Boost
    Just a quick question. My homeboy needs to know if my 310cc precision injectors will be sufficient for a d15b with a sub 200hp setup on it? Will a walbro even be necessary?
    Trend settin'
    Im gonna go with No. My duty cycle is fairly high even with 450s so i would imagine 310 would be extremely insufficient. Always swap out the fuel pump too, you will end up doing it sooner or later. Why risk your engine to leaning out at high rpm?
    Warner robins ,Ga
    you might want to go 440s or dsm 450s. yes to the walbro.
    walbro and 310cc probably will work, but you'll be pretty high on duty cycle and risk failure especially if you loose some pressure. stock inj (240cc) are usually good to 180whp maxed out w/ stock pressure. 310cc around 200-210whp. you could probably do it, but i wouldn't risk it.
    dc5
    ATL, GA
    got some rc 750s with clips forsale if you want some...
    Your Mum loves me. Ace's Avatar
    Kennesaw, Ga
    Axix: How much for the RC 750s? Are they used or new?
    Certified Gearhead miro_gt's Avatar
    Quote Originally Posted by TheChosenOne
    to your questions: yes, and no.
    I ran quite some time with the stock 240s at 162whp/158wtq, and then I ran again quite some time with the stock fuel pump and 440s at 232whp/206wtq - I just had to change the fuel filter cause it was like 13 years old.
    so he's perfectly fine.
    p.s. By quite some time I mean 2 years.
    Certified Gearhead brandenj's Avatar
    small town loganville
    yeah ive heard stories like that and ive also heard stories that stat off like" so i was going to work and as soon as i hit 285 my fuel pump went out" so u can do it but if u have the money it would be a wise investment in case your stock one does go out, but yeah make sure u change ur fuel filter for sure. i'd recommend 440's as well thats what im running w/ less that 200 whp on my d-series just in case i ever get the urge to up the boost some
