Thread: Hondata S300 ECU
    Shining Bright
    Default Hondata S300 ECU
    I bought this and now have no cash and need to let go of some parts... It is in excellent condition and is used but was used on a GSR for all of 4 months. Its for an obd1 B-series motor. I'll throw up a price of $500 OBO as I think this is fair for the ECU as its not just a chipped stock ECU, its a true HONDATA ECU. It uses USB to connect to your computer and the software is amazingly easy to use. Very idiot proof
    Built on the proven s100/s200 code base
    USB connection for speed and compatibility
    SManager Windows based software for parameter & table editing, calibration uploading and datalogging.
    Real-time updating of ECU
    Built in calibrations for common engine combinations
    Built in datalogging to a laptop
    On board datalogging memory (2 MB memory, 20-60 minutes datalogging)
    Adjustment for different sized injectors, with overall fuel trim.
    Configurable for any MAP sensor (to at 5 Bar and above)
    TPS based table lookup for ITBs
    Engine protection from over boost.
    Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
    Launch control with anti-lag Full throttle shift
    Two multi purpose outputs for nitrous control or similar Lambda tracing (with a wideband o2 sensor)
    I need cash now so no trades at this time, unless u have some injectors and some cash... I need 550 and above injectors plus cash... let me know.
    pm me and I'll get back to u asap.
    Lovin life, even if its in a pink car!!!
