Alright, so I somehow got suckered into replacing the headgasket on a 93 Civic for a girl I know. What is the fastest way to get the timing belt off the cam pulley? The directions show to remove all the other accessory belts and stuff first then release a tensioner. Could you not just remove the rocker arm assembly then tilt the cam up from the distributor side to release the tension on the belt/pulley?
How do you guys like to do this?
The belt isn't being replaced as it only has a couple thousand miles on it.
