Results 1 to 33 of 33
Thread: Mainstream Performance OEM Built GSR
    Default Mainstream Performance OEM Built GSR
    Here is a motor I recently built. Tuned it for 45min, cause it took us the first 45minutes to get the damn thing to idle right :P Motor had 20min of running time and 3 oil changed before i put it on the dyno.
    SAE 182whp STD 185whp
    GSR Longblock STD bore
    PR3 Pistons
    Rocket Motorsports M22 camshafts and valverain
    Skunk2 Cam Gears
    SMSP Production 4-2-1 header
    BLOX Intake Manifold
    RPM Service 70mm throttle body
    J's Racing Whale Penis Intake :P
    DFE STAGE 1 Street Head work
    Omnipower Valves
    Im impressed since it only say 15 pulls and made this much. I figured if it hit 180ish i would be in business for 190-195whp.
    NO CAM GEAR TUNING
    POWER never peaked cause his injectors at 8200RPMS were at 117% duty cycle
    We had base timing set, and it wasnt making the power i wanted it to, so Scotty started adding a degree across the board, and it came alive and kept making power, about 2whp per degree. I think the head was milled without my knowledge and the timing is off. we stopped adding timing due to his injectors already maxxed out. We'll retune in 2-3weeks when he gets bigger injectors, FPR, and gauge. this was through a 2.25in crush bent exhaust as well
    200whp or bust
    those are stock injectors maxed out at 15.0 a.f?
    West palm beach
    how much you asking for this motor?
    NO ADVERTISING
    -IA MANAGEMENT
    known as Charles
    We had already taken the Wideband out so we could do Closed loop tunning (gas prices are a bitch so we have to tune for fuel economy also). The car was tuned at 13.5 a/f but would go up above 14 since the injectors were maxing out.
    Quote Originally Posted by punkr6
    its not for sale, i built it for a customer
    so how much u do another one for? if mtr is supplied and if mtr not supplied.
    more than a little, and less than too much
    see, that wasnt so hard. that helps us out alot. thanks pal.
    LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    i tune aggressive on afr IF it makes power AND doesn't detonate, but not that aggressively. the exhaust only had one o2 bung and i wanted to make sure it ran ok w/ closed loop re-enabled. that final pull was w/o the wideband installed.
    Certified Gearhead dwnsthGABOY's Avatar
    Dec 2003
    Amsterdam, Netherlands
    hardy...har...har. LOL!!!
    Quote Originally Posted by admin
    whatever dude? 1,000,000 says you suck my dick while Fox News reports it
    Banned Jon00's Avatar
    Dec 2003
    Grayson, GA
    damn that makes me what to get a other honda
    hey vteckid do yall build turbo motors to ?
    Quote Originally Posted by Jon00
    yes, im building 2 600+whp turbo motors right now. should be done in few months
    Weekly Gwinnett/Junciton Meet
    man u know i have been wanting 2 build my motor...been askin u price for few things for past month or less. I don't want my GSR really agressively built...sumthing i can abuse everyday and still got good mpg and realiability. How much did dat tune or build up cost?? PM the price so i can start savin
    Dec 2003
    Grayson, GA
    make it 700 whp+ and ill have u the cash
    i am shooting for 600whp on one, and 800whpo on the other, but more than what the motor has determines whp.
    Quote Originally Posted by UpSideDownDesi
    $5000ish
    but i can do something similar depending on waht you have
    PM me for prices on builds
    I need tuning on the C5 w/ just a VAFC I and ST Corsa cam gears...need the bung welded on too.
    What effect is running the straight pipe with cat and resonator going to have on it? I guess kill the topend results?
    To 942JZGTE 93H22ACX's Avatar
    big numbers
    94 Supra= 500rwhp
    Quote Originally Posted by 93H22ACX
    big numbers
    I said SHOOTING for, i woulw be happy to have just 550whp under my belt.
    Dec 2003
    well after having a b16 swapped into a hatch, about how much would it cost to have 180-200 whp.
    Quote Originally Posted by dwnsthGABOY
    i just sold a header to a guy and we tuned his b16 and it made 175whp
    SParks Racing Header-$600
    CTR Cams-$300
    AEBS Intake Manifold-$150
    thats all he had, and we tuned it with uberdata and got 175whp out of it.
    200whp, your honeslty looking at $4000-5000.
    itll be ok, i suggest running open header and then bolting your exhaust back on, the differences are usually a few whp up top. but a resonator and cat will prob hold back 4-7whp
    Dec 2003
    CTR Cams-$300
    hmmm...that actually is pretty good.
    what if you used some m22 or m24 rocket motorsports cams how much would that change the hp if any difference at all.
    damn i love your avatar i cant help but to stare at it for minutes lol...
    94 Supra= 500rwhp
    Dec 2003
    why thank you!!!
    Senior Member 99SI's Avatar
    Jackson
    [QUOTE=vteckidd]i just sold a header to a guy and we tuned his b16 and it made 175whpQUOTE]
    hrmmmmm, 175 you say????????
    [QUOTE=99SI]
    yeah i called you that night remember dork.
    His motor was really strong, i have never seen numbers out of a B16 likethat before. i was expecting 160-165whp at the MOST. kinda breaks your heart huh lol. its ok, everyonce in awhile a engine comes along like that and it hurts cause wheni had my "built" and was making 187whp, some guy rolled in with a stock ITR block and all hea had was cams and a header and made 191whp.
    wtf lol
    Jackson
    You told me that he didn't make as much as mine, almost as much. You said that he hit 170 once. Unless yall made some more pulls after you called me. Oh well, I think that opening the head and good header we will definately see the true power of the cams. I don't think the head will flow enough for the cams to make the amount of power they're capable of. *starts looking at credit card balances to see how much I can paypal vteckidd for custom rmf b16 header*
    hmmmm, i thought i told you he made 174.81? maybe i called you when he made 171 or something,hmmmmm. yeah it was weird. i was like WTF. it was a JDM b16 so it had a little higher hp than USDM, CTR cams, Sparks Header, AEBS manifold.
    Its prob the highest whp bolt on b16 i have ever seen. thats more than ITR motors. maybe its the header *shrugs*
    Jackson
    god damn good header. lol
    as i said your midrange was much better than his though.
    Hell, i overlayed my old motor vs the one in this thread, and i had like 15whp and 12TQ on him from 4000-7000rpms. my motor had much more midrange, which is weird cause we have similar builds. hmmmmm
    Jackson
    That is one thing about my motor, it doesn't feel like a b16 anymore with the midrange. I guess peak is pretty but the area to the left has as much to do with power as anything. I just want the area to the left and peak!!! Find out for sure how much Randy would make me a b16 specific header for please. I can't stand it. I don't want any all motor b16's making more power than me. hit me on aim so we will quit whoring up your gsr thread. lol
