Thread: NEED A STOCK FORD 4.6 FOR AN 01 MUSTANG GT
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Default NEED A STOCK FORD 4.6 FOR AN 01 MUSTANG GT
    I need this engine yesterday if you know what I mean! This is for a customer car, I need a totally stock 01 Mustang GT engine, any miles as long as it's strong. This is for one of the big franchise dealerships here in Atlanta, but we are playing HELL finding this engine! PM me or give me a call on my cell if you have got it, I need this ASAP!!
    Matt
    678-542-7537(cell)
    770-968-1245 (work)
    [email protected] (email)
    whats up dude this is me JOSH ( white cobra,white charger, ) remember
    who is putting this in for ya?
    Ellenwood
    It's going to be done at work. It's for a customer's car.
    Ellenwood
    up
    call mcdonough used parts, S & W , LKQ will have tons! too!
    Green Leaf, Jonesboro autosalvage, M&S auto, Morgon auto, one of these will have a few!
    Hiawassee, GA
    Just a little heads up, you can use a 96-98 bottom end as long as you change the fitting off the back of the water pump, and the hose that comes off it to the 99 and up style, and use his heads and intake. This will net slightly more power then stock as well, due to a higher compression ratio.
    Try calling Modular Powerhouse my buddy picked up an old 4.6 off them a while back.
    -Zach-
    1987 Toyota Pickup - Toy
    LAWRENCEVILLE
    i have a 94 ford thunderbird with a good running 4.6 13xxxx miles with a bad auto trans ill sell cheap
    Hella stock member!
    In High Definition!! DSGMach1's Avatar
    Sep 2008
    Probably want to be sure its 01-04 since those have the romeo heads and 99-00 have windors. Don't know if you are concerned about that as the only difference is the number of valve cover bolts, slightly different timing cover, and press on cam gears instead of bolt on. Also MPS in Winder will have plenty.
    http://www.mpsautosalvage.com/produc...t.cfm?TypeID=5
    Hiawassee, GA
    Quote Originally Posted by DSGMach1
    Until April of 01 they were all Windsors. Then until june you had a 50/50 chance. The only difference on the timing cover was 4 bolts, same spot, just slightly bigger.
    -Zach-
