Thread: Help Car trouble.
    Default Help Car trouble.
    Ok so I have a 99 Miata with virtually no mods, the only "mod" it has is the over clocked ecu and the cat has been hollowed out.
    Ok on with the problem, it just started today about an hour ago. When I go to give it almost any amount of gas it wants to cut out. I replaced the plugs, fuel filter about a year ago and i just replaced the fuel pump like 4 months ago. If I slowly give it gas it will rev up but any abrupt throttle increase and it cuts out, not stumbles but just cuts out. Also when I go to start it it wants to stumble when starting. It idles kinda high at first but then it will go down to a normal idle and sit there perfectly.
    Any ideas?
    check your o2 sensors, injectors, fuel filter
    JDM TYTE AnthonyF's Avatar
    So...your saying it will idle, but once you accelerate it will bog VERY badly or just cut the fuk off? lol.
    Sounds like symptoms of a MAF. Can't tell too much w/o the car or more symptoms.
    -Ant.
    The Carbon Fibered R6
    -Ant.
    the motor would STOP until i let off the gas if i continued to hold the pedal the rpms would go to 0, but if i let off it would "jump start" it self back on
    and for some reason it stopped out of the middle of nowhere.
    EDIT: by stopped i mean it started running right
    and i unplugged the maf cause i thought of that and it changed the way the motor was running.
    and when cranking i could smell fuel. on person said something was causing it to flood, but that doesnt really make sense cause over clocking the ecu makes it lean out a lil bit.
    sounds sorta like my car... YOUR CAR CAUGHT DA AIDS.
    Grease Monkey JBizzlebone's Avatar
    Stockbridge
    TPS is probably broke and is staying in the closed position, hence it idling fine. You could try and take your TPS off and see if the lever still has tension on it. If not and it just flops around, replace it.
    except its not 2 stepping, its just dying.
    Clean the MAF.
