Results 1 to 19 of 19
Thread: gas smell
    89 240 rmeyer114's Avatar
    Oct 2008
    snellville
    Default gas smell
    sometimes i get a really bad odor of fuel inside my car when im driving any ideas on what that could be ?
    95 mk3 jetta celebration edition
    -Rob-
    blank
    nowhere
    need more info yo
    Oct 2008
    snellville
    what kind of info u need i can give it to u but this is what i can give off the top of my head... it does it at random times and the cat on it is new and the car ONLY smells like fuel on the inside never gets that smell on the outside when its just idleing
    -Rob-
    Alpharetta, Ga
    check your fuel pump in the rear.... i bet the door where the fuel pump is. is not sealed right and you have fuel pooling on top of the tank... if what you are talking about is that 240 in your sig.
    The G Spot Hero
    Quote Originally Posted by Dirty Mech.
    that would be my first blind guess also.
    Oct 2008
    snellville
    yeah its the 240 in the sig.....ill definatley take a look at that preciate it guys
    -Rob-
    EAGLE TALON TSI Sauljr219's Avatar
    Duluth Ga
    i have an idea look at ur fuel reg. mine was leaking and i had a bad fuel smell
    Eagle Talon AWD TSI
    Quote Originally Posted by Sauljr219
    If the fuel regulator is leaking, then he could smell it from the outside. but he had stated that the smell is coming from inside the car when it not moving.... so how is it the regulator?
    Out in the Boonies
    Friend has the same problem. As Dirty Mech said ... check ur fuel pump.
    Northwest Georgia
    mine does it on a full tank with my 93 civic cx when i take hard turns, only does it if the window is down. Its the seam at the top of the tank where the cap neck is welded. I'm gonna replace it sometime before next spring, it gives me head aches.
    Duluth Ga
    Quote Originally Posted by stock05evo8
    just a thought who knos big guy
    Eagle Talon AWD TSI
    Oct 2008
    snellville
    well ive figured it out its because my springs are cut when i go over bumps it sloshes the gas fumes around and what not
    -Rob-
    Certified Gearhead Juggernaut's Avatar
    Soon to be Kennesaw
    O-ring on your fuel pump cover. Common problem on 240's. 10 min and $2 fix.
    Oct 2008
    Default Re: gas smell
    hello,
    First of all you have to check your fuel pump that it was seal. You have to check all the fuel pipe claims. Inside and outside both you have to check. May be it was loosed that's why your fuel was split. It is not minor matter beware for it. Thanks...
    athens
    height and/or rigidity of the car?..i dont think thts ur problem. gas sloshes in everbodys car..urs is just getting out...=bad. did u chek wht other ppl said?
    Oct 2008
    snellville
    doesnt really matter right now the cylinder heads blownlmao
    -Rob-
    Oct 2008
    same problem with my s14
    you don't know me zero-60's Avatar
    check all fuel lines, everywhere. colder weather causes parts to contract a little more and sometimes clamps work themselves loose.
    L.R.
    POVERTY
    gas.brake.scrape.scrape.
    Senior Member boosted b's Avatar
    could be a fuel injector
    Lsu tigers going # 1 again
