Results 1 to 39 of 39
Thread: New Track Time
    Member of Broken Dub Club SPL_Jetta's Avatar
    Valdosta and Alpharetta
    Default New Track Time
    ------2001 Cobra-------2001 Jetta
    R/T ------.986 ----------.419
    330-------6.549----------6.589
    1/8-------9.568---------10.039
    1/4-------14.220---------15.490
    MPH------101.07----------91.44
    It was against a suped up Cobra, and was randomly selected to go up with me. . .real fair, but n e ways, not bad for 200 lbs of stereo equipment in the back
    SpeedMonkey_ benwaballs's Avatar
    MI
    not 2 bad.. what mods you have done?
    GIAC socket type, Injen intake, GReddy exhaust, 007
    MI
    DP will make a night and day diff on the car! you should have no problem hitting 14's
    Apr 2003
    Acworth/Kennsaw
    lets see what it runs w/o the 200 lbs in the trunk
    2.0TRawr ironchef's Avatar
    Shouldn't the cobra have been running faster?
    Apr 2003
    Acworth/Kennsaw
    ^thats what i was thinking
    last time i saw a cobra at the track it was running low 13s high 12s
    but i wasnt sure if it was modded or not. But you would think thats what the run stock is 13s..im bored im gonna do a little research
    Apr 2003
    Acworth/Kennsaw
    from what the site below says, the 01 cobra stock runs 13.5 in the 1/4
    http://www.albeedigital.com/supercou...0-60times.html
    Quote Originally Posted by Chuckster
    BUT thats with a good driver, dont forget that
    Chris, is there a track in valdosta?
    yup, 10 minutues up I-75, 15 bucks all you can race, i went 21 times and i sat out for 30 minutes too. No rules, as long as your car runs, has good condition tires, your good to go, oh yea. . .and sign the waiver, there is never any more than 25-50 cars
    MI
    Quote Originally Posted by SPL_Jetta
    is it a 1/4 or 1/8?
    Quote Originally Posted by benwaballs
    is it a 1/4 or 1/8?
    1/4 mile track, with another 1/4 mile for slowing down
    www.sgmpracing.com
    Attached Thumbnails Attached Thumbnails -pic009-jpg
    old school fool Allstar3.8T's Avatar
    Loganville Ga
    What boost is it putting out?
    What was your 60' time?
    What gas were you running? (all gas is bad now btw...)
    Not a BAD time, but something seems a little off. Not to dis on you, but maybe we find it and knock off 2 or 3 tenths. I have ran one OEM to a 15.6... so chipped even w/ audio should walk it I'd think. 200 extra pounds versus a chip adding minimum 20 WHP and 40 WTQ is over come easily.
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    Apr 2003
    Acworth/Kennsaw
    i pretty much got the same set up, but ko3s and GHL cai intake and 2.5" magnaflow exhaust and ran a 14.7 with my gurl in the car and she doesnt way much like 120
    Quote Originally Posted by Allstar1.8T
    1) i dont know
    2) 2.418
    3) 93 bought in august
    I found it really hard to get good traction, all i was doing was spinning my tires. I had to slowly ease into the gas, if i popped the clutch i literally just sat there spinnin and spinnin and spinnin, lol.
    Once i get bigger radius tires and wider tires it will be easier for traction. I was using older tires, and i did not burn them before i launched, and i kept driving through water to get to the trap. All those factors will definitely hurt the launch, and thats the only place where i had problems.
    I even managed to beat an IS 300 which is something to me. Also this was my first time at the track. My exhaust is GReddy, which apparently to EPG's knowledge caused an overall decrease in power, and i only had a chrome Injen intake. The only thing helping me really is the chip and a little of the intake.
    I dynoed at 187/217 btw.
    Any comments, apparently this is slow as balls i guess
    Oh yea. . .and this is slowly turning into a show car, not really for track, i just went because in Valdosta there is nothing else better to do
    Apr 2003
    Acworth/Kennsaw
    not really, iv seen worse w/same mods or more. vdubs get alot wheel hoop. Vdubs also suck elephant nuts when it comes to heat soak
    MI
    what is this heat soak you speek of?
    Chambodia-
    don't forget about the spider hiding in your trunk
    Attached Thumbnails Attached Thumbnails -t_bigspidercloseup_187-jpg
    Apr 2003
    Acworth/Kennsaw
    fuck that bitch i kill him!
    Loganville Ga
    Forget brands for now...A chipped 1.8T is a 14 sec car. Mine w/ a chip on 100 oct did 14.195 @ 100.16. No other mods. The worst it ever did was a 14.7 w/ someone else driving it, and they missed 3rd gear. (I know it was spiking to 24 psi, holding around 18-19). Treys 337 chipped on 93 octane did a 14.2.
    I'd try these few tips;
    -Try to AVOID at all cost the burn out box on street radials.
    -Dont spin street tires hard prior to running...street tires can get greasy w/ heat if they are cheap...also our clutches need rest, not additional abuse.
    -Keep the car off as long as possible.
    -When you crank it turn on the A/C to spin the additional fan...then turn it off when you turn off tract control (which ever type it is...OFF)at the burn out box.
    -Dont drop the clutch to launch. Slip it as you increase throttle. This is a proven better launch idea on a drive by wire car where the throttle is never in the same place twice.
    -Remember spinning is better than bogging, but less is best.
    -run once or twice, and let the car rest. 8 runs in a day is pushing a turbo car (heat is the enemy obv) 20-25 times would explain some of the results IMO.
    Try to shoot for a 2.2 60' next trip, because a 1/10 in the 60 shows 2/10 in the 1/4 generally.
    Good luck;
    GC
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    Good luck;
    GC
    Well, that 14.1 was with 100 octane, mine was with 93, which is a big difference. A 337 has a ko3s i think? which if it has has a little advantage over me.
    The 15.4 was about my 17-18th run, my first run was 15.7 and i hopped all throughout first, so you can see how the heat is killing it. Then again, this is NOT a drag car, i did it for fun.
    Also my car is 70,000+ on all the OEM engine components, doesnt the turbos usually give out around this time? I hope so, so i can get a new one, or a ko3s or bigger
    Also, would a N75J help me at all? Im not feeling any surging problems, but wouldnt that help me maintain higher boost? isnt that the point of it?
    MI
    get the down pipe!
    get the down pipe!
    Give a college kid $400 so he can get a downpipe!, lol
    Apr 2003
    Acworth/Kennsaw
    400?? shit you can get them cheaper then that and install the bitch ur self aint hard just takes a little muscle
    Well, actually i just wanted a little extra money, i can weld myself, lol
    MI
    i paid 200 shipped 2 my door for the 2 1/2 APR dp... go 3" dont listen to the haters no one races from the dig anyway...
    Apr 2003
    Acworth/Kennsaw
    hey jon here i san idea, you sell me ur 2 1/2 apr dp and you go get the 3"
    MI
    lol i would but i sold that downpipe w/ the GLI... i am 3" all the way back now.. thats why it is so damn loud
    Chambodia-
    you shoulda of bought mine!!!!!!
    Chambodia-
    depends on how u take care of it im guessing
    im pushing 140k on my stock turbo..been chipped for 80k miles and my turbo finally gave way 2days ago
    Apr 2003
    Acworth/Kennsaw
    ^^^ oh shit bigger turBOOOOOOOOOOOOO, here it comes!
    Loganville Ga
    Theres a 2 1/2" DP at Assist Racing he'll take $100 for, ask for Scott.
    BTW, 100 oct. gas adds 3.5 lbs of boost making about 30-35 more WHP... that doesnt change it 1.5 seconds.
    I did run a 14.3 @ 97.xxx on 93oct at commerce in may (With stereo on 20"s) w/ only 15 lbs of boost (small cut in a vacuum line was holding it back) If it been at 19-20 like normal, I'd like to think a 13.9 would have been in reach on pump gas and full show gear.
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    ill gladly take that DP for $100. Only problem is that im at Valdosta right now in college, and i can come home on the weekends sometimes, but i definitely want that DP
    Apr 2003
    Acworth/Kennsaw
    where is this Assist Racing at?
    have # to this place
    what kind of dp
    and is it for a Jetta
    MI
    it will work on a jetta/golf dosnt matter
    Loganville Ga
    Its in Stn Mtn off of Hugh Howell near USA auto sales (stn mtn freeway) He had it sittin at the shop a month ago or more, 2 1/2" it appears to be an APR, but not sure. He said $100 would take it from him. Scott only had the one DP, so game on to get it!
    I'll post the # when I dig it up...
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    -=Mi4=-
    danm, didn't read the wholething but mid 15 second on chipped jetta???
    jetta 13.9 @ 99.6 2.2 60' no spare, n75j, upsolute, 93oct, hyper boost, milltek 2.5 tb ...now RIP
    gti 14.9 @ 93.5 2.2 60' stock! cai+dv
    Chambodia-
    does this DP include a high-flo cat?
