Results 1 to 2 of 2
Thread: non obd b16 troubleshoot
    Atl
    Default non obd b16 troubleshoot
    hi guys. here is my problem. i currently have a obd 0 b16 in my eg hatch. i use to have a ls vtec which was ran with a obd1 gsr engine harness and a ls p75 ecu chipped and tuned at mainstream.. ok.. i pulled the ls vtec out because i didn't really trust it and purchased the obd 0 b16 and put it in there. ok.. so im using the gsr harness and p 75 ecu on the b16.. It cranked up obviously with codes. 6 10 and 14 were thrown. ect, iat, and iacv. there are so so many extra plugs on that harness so i assume that they are in the wrong place. What can i do to fix this?? which wire or connector diagram should i follow?? what would make things easier??
    credibility and reputation
    i normally lay the harness on the engine and everything lines up.
