Results 1 to 14 of 14
Thread: some help
    is doin you
    buford
    Exclamation some help
    ok igot a 97 civiv with a b20 swap and on a p75a OBD2 ecu
    im trowing the code p1337
    can someone help me do this:
    http://honda-tech.com/zerothread?id=1029958
    "It is an easy way to disable (actually tricking the ecu not disabling it) the ckf sensor when swapping a non obd2 motor into an obd2 [color=blue! important][color=blue! important]car[/color][/color]. Just splice C1 to C4 at the ecu and c11 to c14 (not sure if this is necessary or not but I did it) and you are ready to go.
    I came up with this idea when I realised that the CKF had 12 points at the crank and I was pretty sure the ckp was 24 at the cam on obd1 and 2 distributors. I searched to see if any one else had tried it and this is the closest post I found to anyone even thinking of it so I am posting it to save everyone else the trouble of swapping oil pumps. " This will work when using a US OBD2 ecu as well.
    ATL, GA
    wheres the miata?
    is doin you
    buford
    up
    Gainesville
    and this is why i sold my honda
    its not to hard, just find the C clip at your ecu, splice the wires shown, and viola you are done.
    however if you want to do it right...id change the oil pump, i had done this to my prelude a while back when i swapped in a f20, but ended up swaping out the pump and the sensor...just as a piece of mind
    is doin you
    buford
    i read yoiu dont need to^^^^^^^^^^^^^
    ALL CAPS JITB's Avatar
    *shakes head* what did u do to the miata?
    :noitacoL
    that means your car is too "leet."
    is doin you
    buford
    leet??? wtf ..noo its a obd1 motor in a obd2 car...so i have to do this to get the code off
    is doin you
    buford
    yay!! picsS..thanks!!!
    :noitacoL
    Quote Originally Posted by bikerj11
    leet??? wtf
    http://en.wikipedia.org/wiki/Leet
    is doin you
    buford
    *rolls eyes*
    yes change the oil pump an do it the right way! if you look on yours it might have the spot to install the sensor an you dont have to change it, might get lucky! BTW I have the sensor if you need it!
