Results 1 to 10 of 10
Thread: Shifter Problems
    gwinnett
    Default Shifter Problems
    Okay, so everytime Im in gear like first all the way through fifth and even reverse the shifter is loose as hell, it goes from side to side ... sideways literarilly. Im thinking its the bushing that holds the shift linkage connected with 2 12mm long bolts to the chassis ? The car is a 94 civic 4 door ex.
    Reps awarded for any answers.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by JDMirza
    There's a number of things.
    1. Make sure there is a pin, not a bolt connecting the shift shaft linkage to the trans.
    2. Check the bushing you mentioned.
    3. Check the bushing on the bottom of the shifter, where it connects to the linkage.
    4. Check the bushing where the linkage bolts to the trans.
    Morrow 30260
    Usually if the bushing you mentioned is missing, the shifter will move up and down a lot as well and sometimes even fall down completely.
    the bushing or bolt at the bottom of the shifter.
    x2
    JDM TYTE AnthonyF's Avatar
    I agree. Espically on such an old car. Bushing could be just worn out.
    -Ant.
    The Carbon Fibered R6
    gwinnett
    Thanks everybody. Reps.
    Sep 2008
    lithonia
    liike they said....
    Slimm
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    which bushing yall are talking about? yall mean #11 right??
    NIKON Squad member 05
    Mah shit thread
    im talkin about #s 18 and 15
