Results 1 to 23 of 23
Thread: Card reader to PS3...
    Default Card reader to PS3...
    I have no idea why I can't view pics or video or anything from my PS3 when I put the card reader in the slot. The PS3 recognizes it as you can see it in the lists under VIDEOS or MUSIC, but it says there si nothing on the card when i know there is.
    Any ideas? Thanks. Later, QD.
    R A W! x Resilience's Avatar
    Atl
    I don't know never got a problem like what, what you can do tho is get a flash drive and put the pictures on there and then plug the flash drive into your PS3. It should work because thats how I got my stuff on my PS3.
    I know that didn't answer your original question but it might help ya.
    Targus USB 2.0 Memory Stick Card Reader/Writer for Memory Stick
    I have the above. Is that not the same thing? Later, QD.
    YoTa_BaNgEr YoTa_BoX's Avatar
    Dec 2003
    In a Yota
    you may have to format the card to the Ps3. With the psp the only way you could look at pics and videos you had saved to your card was formatting it to the psp. I don't own a Ps3 but i think thats what may be wrong. Delete everything on the card then stick it in the usb drive then back into the Ps3 and see if there is an option to Format it.
    Life is a thought, think about it.
    Atl
    It is kinda, but it would be a whole lot easier with just a flash drive.
    I'd try to format it like said, but that would mean losing everything thats on it so I dunno.
    If you happen to have a flash drive laying around, I'd put the files I want on the PS3 on the flash drive then plug the flash drive up to the PS3.
    Sarcastic Asshole fivex684's Avatar
    Jefferson
    I have had this problem myself. This has always worked for me. Go to music or videos and what you want to view and click triangle on the card then click view all. Hope it works.
    Chris / 97' Volvo 850R Wagon / 86' Porsche 944 Turbo
    Dunwoody
    QD I had the same problem when I first got mine as well.
    What you have to do is under whatever category you want say for instance Music, is go to that section select the card reader and hit triangle. At that point it will open a menu. Hit view all and everything should appear. If you have any other problems just PM me.
    SoooperDooooperLS
    Read the instruction manual and use Google noob.
    I've done that from the beginning and it shows I have nothing there. Even states it, lolol. Later, QD.
    That's odd, since it should show up when you go to show all under the XMB menu pop up when you hit triangle. . (which PS3 did you get 20,40,60, or 80?)
    I don't remember. Lolol. It does NOT play PS2 games. I think the 40? Later, QD.
    Dunwoody
    Hmm weird. The only thing I can tell you then is to hit the PS3 boards. Good luck. The only other thing that I can think of is maybe the formats wrong but I doubt that video does have to be converted in most cases to go on the PS3. If I should think of anything I'll let you know
    I'm registering on PS3 forums now so I can find out what's going on. I mean the PS3 recognizes the card reader being in there. It just keeps saying there's nothing on it. Later, QD.
    Dunwoody
    ever find the solution?
    Advan Kid
    QD, This is a step by step on what to do.
    In Windows:
    First Format the memory stick to FAT 32.
    Right Make new Folder , NAME THE FOLDER PS3.
    Then Double click on the PS3 folder,
    Make your Sub folder as MUSIC and VIDEO and such.
    Place your mp3 or music formats in the MUSIC folder
    Then Your Video formats in the VIDEO folder.
    You get the idea.
    Then when your finish with your puting your files in folders.
    Take out the usbreader with memstick from the computer and put it in one of the usb slots of the PS3 system.
    Boot up and your formats will be in the corrsponding category.
    firren muh laaazahhh stephanie's Avatar
    Southside
    what are you trying to do?
    Quote Originally Posted by gtrmonkey
    In Windows:
    You get the idea.
    Actually, that worked perfectly for pictures. Or rather one pic that I tried. The one video I put on the card wasn't recognized by the PS3. The video was in .WMA format. Maybe that was why?
    Stephaine, I'm simply trying to move stuff around from computer to PS3 with the above. But I think I've got it now. Later, QD.
    Love da wifey Nex's Avatar
    im no genius. you can try formatting the card when the card reader is attached to the ps3. then transfer files on the card with your PC. sometimes the device reconizes the card when it is formatted by it.
    Kennesaw, Ga
    Videos need to be in MP4 format for the PS3 if I recall correctly.
    You can download http://www.erightsoft.com/SUPER for free to convert your vids.
    Southside
    Glad ya got it sorted out. I have hooked my camera with the usb to my ps3 to put pics on it.
    I have a 40 gig, only the 60 plays ps2 games.
    Advan Kid
    No the the Video Formats for the Ps3 are the following:
    * Memory Stick Video Format
    * - MPEG-4 SP (AAC LC)
    * - H.264/MPEG-4 AVC High Profile (AAC LC)
    * - MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
    * MP4 file format
    * MPEG-1 (MPEG Audio Layer 2)
    * MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
    * MPEG-2 TS(MPEG2 Audio Layer 2, AC3(Dolby Digital), AAC LC)
    * MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
    * AVI
    * - Motion JPEG (Linear PCM)
    * - Motion JPEG (μ-Law)
    * AVCHD (.m2ts / .mts)
    * DivX
    * WMV
    * - VC-1(WMA Standard V2)
    try this:
    To play WMV format files, you must go to (Settings) > (System Settings) and set [Enable WMA Playback].
    Duluth, GA, us
    make a folder called PICTURE just like that and it will show up just go triangle then display all it should show up...
    What ps3 do you have 40, 60, 80 etc.
    GooKy
    Formerly known as wTnLeGeNd
    Duluth, GA, us
    add me on ps3 and we can go in chat and i can help you out
    jiggawin
    GooKy
