Results 1 to 10 of 10
Thread: car shaking really bad
    All Motor EK N/A EK's Avatar
    On IA.com
    Cool car shaking really bad
    I have a problem w/ my car around 60mph, it starts shaking really bad when I give it some gas. As soon as I left of the gas it's fine. What could that be, mayb the axels
    Kinda lame IRL isa2o3's Avatar
    does it make any noises, i am thinking wheel hub bearing
    :noitacoL
    does the steering wheel shake or like the whole car has seizures or something?
    IA's culinary pro TheGrillMan's Avatar
    darn, i have a similar proble and was about to post lol
    athens
    u could be having a misfire
    ..does it stop ahking when u let off the gas or after uve let off and slow down, maybe u just need to get ur tires balanced.
    Oct 2003
    ^^Tires don't do that when you let off the gas.
    You, sir have bad CV axles. Do you have a B series swap? If so the intermediate shaft bearing need to be checked for play. If there's no up and down play, you need to check for play in the CV axles themselves. And while you're at it, jack up the wheels and check for bearing play. If there's up and down movement, you have bad bearings. If there's side to side play, you have bad tie rods.
    Athens
    Hey that's what I was going to say......I have a caddy sittin on my lift at work with the same problem as he has....
    2013 Dart 1.4T 6MT
    boooooostin'
    athens
    no homo
    Quote Originally Posted by WD-40oz
    On IA.com
    ^ Thanks guys, ill be checking out the axels n the rest tomorrow.
    SHO Gun Warrior jc91sc's Avatar
    On Ya Momma's Lips
    Yeah, most likely the CVs are gone and not turning true when you accelerate. Should be a simple fix.
    James E.
    If you've gone from 0-60mph in 4.5 secs, you know what ADRENALINE is!!!
