Results 1 to 11 of 11
Thread: Mono amp with two subs? Help?
    Sep 2008
    Default Mono amp with two subs? Help?
    How would I go about doing this? Can I put one terminal on the box and run wire from that terminal to both the subs? And if the amp pushes 600 RMS and the subs are 300 RMS each, if I have that one terminal will each sub be getting 300 RMS? Amp is 600 RMS at 1 Ohm and subs are 4 Ohm DVC wired down to 1 Ohm... First system, thanks for the help.
    SHO Gun Warrior jc91sc's Avatar
    On Ya Momma's Lips
    Well, to truly tell you how it needs to be run, we'd need to know the brand and model of the amp and its specs, as well as the subwoofers themselves.
    A quick version:
    Connect the two speakers to one another parallel (positive to positive & negative to negative), then run the wire from one of the speakers to the amp. If it's a good mono, it should be able to run in the 2Ohm or 1Ohm load.
    James E.
    If you've gone from 0-60mph in 4.5 secs, you know what ADRENALINE is!!!
    Hiram, GA
    Wire your subs in paralell/paralell
    The run the positive and negative to the pos and neg posts on the amp.
    Sep 2008
    Quote Originally Posted by BanginJimmy
    And this will give me a 1 Ohm load on the amp?
    Certified Gearhead Silvrmaxx's Avatar
    G-nett
    if the subs are dual voice coil...
    Shift_Clean
    Hiram, GA
    Quote Originally Posted by iDrum182
    You said that the subs a 4ohm DVC so yes. Each sub would be a 2 ohm load, then paralell the subs down to a 1 ohm.
    G-nett
    ^^this guy's good
    Shift_Clean
    ATL, GA
    Quote Originally Posted by Silvrmaxx
    ^^this guy's good
    pssshhhhh maxima's suck
    Sep 2008
    Yeah they are 4 Ohm DVC. Thanks.
    cleveland,tenn
    i dont really listen to anyone else on here except this guy big help to anyone that is lookin for some advice =]=] thanks
    Dec 2008
    Hey dude you just joined CA.com didn't you? Invite is still open if you're ever out my way to hear the AQ
