- Unpolished...
- Rep Power
- 24
Unpolished...
Sup IA- Just wanted to see if I could get some opinions on my car. It feels a little rough around the edges. I'm sure it's a little hard to know exactly what to do w/o riding in it. But here's a list of things I would like corrected.
Suspension- Car has a slightly bumpy ride and scrapes a little in cornering. I know it can be raised up and that would solve the scraping issue. But as far as ride quality goes what would be a good setup to go with? I know somebody will say koni/ground control but I want something other then that setup.
Shifting- Ever notice if you have a passenger in your car their head moves forward or backward when you shift? I don't shift hard but I want the process of going between gears to go as smooth as possible; if possible to the point of a passenger not even knowing you are shifting w/o looking
Appearance- That black mold/grimey buildup on the rear triangle windows is annoying, anybody have a suggestion on how to get rid of it and keep it from coming back? Is it caused just by normal weathering?
Is there any type of underbody coating that you can spray on and keep rust from building up sorta like that rhino bedding stuff people apply on the beds of p/u trucks. It'd be nice if it also provided easy dirt removal.
The engine is pretty much bone stock except for I/E. And almost everything has been replaced recently. Spark plugs gapped to oem specs, new wires, gaskets, thermostat, royal purple oil, and a few other things. But it stilll runs a little loud. It'll be getting a new timing belt water and oil pump soon but as of right now it just doesn't run as smooth as i'd like it to. Any place I can take it to make sure everything is within spec?
My gas mileage seems a little low as well i usually average about 300-320miles per tank. Is this normal or could it be a little better?
Sorry for the long post, but if anything else comes to mind i'll def post up. Thanks in advance.
- Unpolished...
- You may not post replies
- You may not edit your posts
Forum Rules
