Results 1 to 11 of 11
Thread: sleeping much ?
    ~THE UNDER DAWG~ ghostfacekil's Avatar
    Default sleeping much ?
    dont sleep on it ........
    The Spyker C8
    The Spyker C8 Aileron continues Spyker's signature architecture (applied since its inception in 2000 with the C8 Spyder) of a mid-engined configuration in an aluminium space frame, clad in aluminium body panels.The Spyker C8 Aileron's space frame is a development of the original space frame of the first generation cars: its torsional rigidity, however, was improved by 40% without adding any weight. Its dimension have changed though, the wheelbase increasing by 10 cm / 4.5 inches for improved road handling and more cockpit space. Also its front track was widened and as a result the car is virtually „square.
    </SPAN>
    Design
    Designing a successor of a first generation car is no mean feat. Spyker's design philosophy has always been to create timeless designs, contemporary but classic.In the first generation cars the leading design cues were Spyker's aviation and racing heritage. The propeller design consistently applied to many elements of the cars ( such as the Aeroblade wheels ) since 2000, was up for refreshment though: And in aviation the propeller engine was succeeded by the turbine engine so Spyker adopted the turbine as its "leitmotiv" for the Spyker C8 Aileron.
    The signature Spyker polished air inlets in aluminium were converted into turbine engine shaped scoops reducing the "bling" element considerably, which reflects a trend Spyker sees in general: more sober designs, less exuberant. The scoops have polished alloy nacelles which may be colour coded with the interior as an option.The airflow around the car was redesigned so that the shark-like gills of the first generation cars (no less than 17 on a C8 Spyder) could be abandoned giving the Aileron a cleaner, smoother appearance.
    The radiator opening was enlarged in anticipation of more horsepower requiring additional cooling. The mesh is V-shaped as on the first generation cars, a direct reference to the Spykers of the previous century, but angled forward giving the car a somewhat more aggressive stance.Also the headlight units were reshaped to follow the body design more closely. LED lights are incorporated in the units for indicators as well as Xenon lights (which are standard now).
    The glass jet brighten inspired canopy, first introduced on the C8 Laviolette in February 2001, was extended backwards, reducing drag and increasing cockpit headroom. The signature air inlet atop the cockpit remained save that is now turbine shaped.With the increased wheelbase (10cm / 4.5 inches) the doors grew by the same length allowing for more comfortable in- and egress.Unfortunately practicality sometimes gains over design: The first generation cars have split side windows which were not optimal in terms of sealing (wind noise and water management). The Spyker C8 Aileron has single pane side glass that drops when the door is opened and closed, creating improved comfort level.The rear diffuser was redesigned for improved functionality. The redesigned rear lights are LED units.The outside mirrors were redesigned and the cone is mounted on two turbine fan blades, standard in body colour (but available in polished aluminium as an option)
    Power train
    The Aileron will continue to use the Audi 4.2 litre V8 giving 400 BHP. This state-of-the-art 5 valve 4 cam engine is now mated to a 6 speed Getrag manual or a 6 speed automatic ZF gearbox. This is the first time a Spyker is available with such an automatic gearbox as standard equipment.
    Wheels and suspension
    The Aeroblade ™ (5 propeller) wheels of the first generation cars are - logically - replaced by a 10 blade rotor wheel called „Rotorblade' ™. They come in 19" all round and are made in left and right hand turning versions.The Spyker C8 Aileron's suspension was developed from scratch and has double wishbones both front and rear. Shock absorbers are now placed vertically within the wishbones.(Carbon Ceramic )
    Brakes
    Brakes are supplied by AP Racing, a Spyker partner from day one. Colour coded callipers with Spyker script are available as an option. The Aileron is available with carbon ceramic brakes as an option as well.
    Interior
    The interior of all Spykers is clad in the highest quality leather the industry has on offer. The Dutch Tannery of Hulshof provides the six hides used for an Spyker C8 Aileron interior in 14 standard colours, which is fitted by Ellemeijer. Any other colour so desired by the customer is available as an option.Chronoswiss Dials are available as an option as well.
    i'm a got dang wallaby!!
    SPYKER IS WIN!
    the interior is pimp.... But the car is fugly.
    Never go full retard
    Nashville
    Quote Originally Posted by Bruce Leroy
    I wouldn't say fugly, but I do agree that they've always looked kind of weird to me.
    Riversider
    i dont like it!
    I love the Spyker C8...the interior is just so flamboyant and outlandish...I think that's the only reason I like it so much. The "propeller" steering wheel is the best though.
    By the way...none of the cars which you posted are the Aileron C8, except for that interior shot.
    This is the Aileron...I don't like it as much as the older C8 though.
    Monroe, Ga
    sorry but i dont like th out side but the inside desreves a rep repped to you man clean car though
    ALL CAPS JITB's Avatar
    Looking at that interior puts me too sleep its looks so comfy...
    Noice
    Certified Gearhead 4drlschick's Avatar
    Oct 2008
    Rome
    interior is HOTT
    95 eg sedan with complete ls swap tons of extras.... SOLD
    88 prelude si lowered like a mother.... TOTALLED
    95 prelude si jdm f22b swap.... TOTALLED
    03 celica gts toooo much money in this one..... SOLD
    92 da teg NEW DD
    89 ef hatch.... SOLD
    95 ex/si coupe (this bitch is clean as fawk)... awaiting swap... NEW hopeful DD
    Macon
    The Spyker is always at the Concours in Amelia Island, and its probably the ugliest car on show. Jeremy Clarkson pretty much railed on this car on Top Gear.
    But yes, the interior is flippin' sweet.
