Results 1 to 10 of 10
Thread: wtf a fuel leak? YEP. But from where? idk....
    SwiperNoSwiping!!
    Default wtf a fuel leak? YEP. But from where? idk....
    Today, i filled my tank up from E to F, and i get it home all nice and fine. The car sat in the garage for maybe a couple hours, and the next thing i know, the whole garage smells like gas. I moved the car out, looked under the hood, sniffed everything, felt for raw fuel... no fuel leaks AT ALL under there....Checked my fuel cap, smelled around it...No leak there either. However, when i sit inside the car, there is a very weak bit of a hint of fuel. So, it leads me to sniff/feel around the backseat area where the fuel pump is located. Nothing from there either. The smell is seemingly only existent from the driver's seat area. Soo, where its coming from? i have no idea.
    EDIT:
    I just let the car sit for ~15mins after running it, and i opened the door, it smells like the fuel leak is coming from somewhere inside the car itself. Also, i've never had any problems like this before with the car
    u remind me of a wigger !
    Don Mon SiRed94's Avatar
    Morrow 30260
    What kind of car is this? Because I am having a very similar problem with my mom's Camaro. And the only place that I see that may even be leaking is the upper fuel injection O-Ring on the number 6 cylinder. And it isn't squirting, just has a little residue that smells like fuel at the top of the injector. But, it smells very very strong outside the car, and you can smell it faintly inside the car. I haven't got to checking fuel pressure and seeing if it is holding pressure and all that yet. I'm almost wondering if the injectors are leaking into the manifold while the car is off.
    SwiperNoSwiping!!
    its a 1990 integra, and none of my injector o-rings are leaking
    EE OG Revmaynard's Avatar
    Man, you sure are having a lot of problems with that car.
    Bozzio for president.
    Senior Member G.C's Avatar
    Forgot
    Check your fuel filter,Injector,Fuel pump,Gas tank under the car,Hoses that goes through the tank to your engine. Soon or later you will find it.
    :idb:
    SwiperNoSwiping!!
    Found it. The filler neck to where it meets the tank isnt tight enough. Driplets are coming out there, making a puddle on the ground below.
    Forgot
    You the black kid that was at mahdavi the other day?
    :idb:
    SwiperNoSwiping!!
    Quote Originally Posted by G.C
    yeah, lol
    インテグラ K20Z1's Avatar
    Buford
    is it ur vtec fluid
    SwiperNoSwiping!!
    Quote Originally Posted by aznnnvtek
    is it ur vtec fluid
    lol, it would be if i had vtak, i think it might be my blinker fluid leaking....or the casings on my muffler bearings arent tight enough and they're leaking out fluid lol
