Results 1 to 18 of 18
Thread: Oil leak while running
    Default Oil leak while running
    The engine is a mid '90s JDM GSR, unknown miles, but runs decent. I drove the car with the hood off ("I have a mullet" style) and ran the car out in the first few gears. I slowed down and noticed some oil on my windshield, pulled over, and checked out what was going on. It's from the driver's side, front of the motor. I can't tell where it's coming from as it will drip down but also get blown upwards. I've tried cleaning off the motor untill it's spotless to see where the oil is leaking from, but I still can't tell. Anyone have some ideas of what I could look for? If it matters, my upper timing cover is off, but I haven't seen any oil from that side of the motor; it's also getting oil on the bottom of the hood, while I'm not being a redneck. If anymore info is needed, just ask.
    Thanks in advance!
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    could be a cam seal or crank seal if the oil is behind timing cover, it could be leaking on the timing belt and the belt is slinging the oil back up
    98 Acura Integra LS-DD
    ??????????????????-project
    Has anyone ever confused you with someone with a brain? The answer is more clear than a Windex washed pane of glass.
    Don't run.
    Easy motherfucking E. Lolol. Later, QD.
    Don't run.
    lol.
    i hate you so hard
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    if it happens when running the car into the upper RPM's i would check the crank breather box on the back of the block to see if it has an *snicker* oily discharge.
    Who knows?
    BB6er IMPORTchic's Avatar
    N. GA
    I have an idea..
    MAKE SOME SENSE!!! How is it come from the drivers side yet wasnt coming from the side with the timing cover?
    FREAKIN TARD!!
    Thinkin cam seals though!
    THank you!! Come again!
    Quote Originally Posted by IMPORTchic
    I have an idea..
    FREAKIN TARD!!
    Well, we all know the B series motor is roughly a rectangular prism, so if it's on the driver's side of the front... then it's not where the timing cover is...
    I still <3 you though, lol
    N. GA
    ......Evan....hunny child...you have lost it!
    I think not!
    Middle, Ga
    Wow man, hope you figure it out! Did this start last night?
    "Damn, Its Tyler"
    RaceReadyDevelopments
    North Augusta, SC
    Does it leak any oil if you are just sitting there at idle?
    Back to being stock and slow
    a dog chasing cars
    Warner Robins/ Athens
    It's futile. It's what Hondas do at our house. Try leaving it at Logan's for a night. That will fix it I am sure.
    North Augusta, SC
    Quote Originally Posted by turbodawg
    You're evan's bro right? I tried sending you pics of a wheel on your phone for the civic. Not sure if you got it or not.
    /threadjack
    Stang Mod slostang's Avatar
    Southside
    front main seal.
    Inside the red is where the oil is, seems there was come confusion, LOL.
    Southside
    front main seal.
    North Augusta, SC
    Quote Originally Posted by slovic
    front main seal.
    repost
    front main seal.
    You do know that's inside the timing cover... and it's spotless in there?
