Results 1 to 5 of 5
Thread: Ever had your Tensioner pulley go bad:Integra
    Monore/Atlanta GA
    Default Ever had your Tensioner pulley go bad:Integra
    Last night driving home my car started making a almost grinding/whining noise. I put my head on the PS line and it sounded like the PS pump but today it sounds more like the tensioner pulley. I think the bearing is shot.
    On the way to work it started making the belt squeal and as I stated to pull off the side of the road it stopped and has been fine since except for the constant whining. I'm gonna stop and get one and replace it but I've not read anything about it happening to anyone else before.
    Anyone had this happen?
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    yes totally possible for the tensioner to seize or start to seize. it should be replaced with every timing belt and water pump done.
    or if you are talking about the PS tensioner i dont think it can go bad, but i may be wrong. Never had PS on my cars
    Monore/Atlanta GA
    Hmmm, makes me wonder if my Timing belt was ever changed around 100k. The motor has 160k on it now.
    stupid question but did you check the fluid in the PS resevoir?
    usually a whining noise can come from :
    Ac compressor going bad
    PS Pump going bad
    Timing belt tensioner going bad
    Water Pump going bad
    Monore/Atlanta GA
    I thought about all that. I checked the PS fluid, it's fine. It COULDbe the A/C clutch cause the sound is right there around that area but it sounds just a little louder closer to that pulley. I'm crossing my fingers it's the pulley.
