Results 1 to 13 of 13
Thread: How to Remove and Install a Fuel Pump in a EJ-EH-EG
    Southside
    Default How to Remove and Install a Fuel Pump in a EJ-EH-EG
    Ok guys well I'm going to walk you step by step to how you can Remove and install your Fuel Pump. So if you have poor comprehension skills, can't read, or have no patience, then take your shit to a shop where they can charge your ass to do it lol. But this explanation is only for the 92-95 Civic Coupe, Hatch, and Sedan.
    Tools that you'll need:
    Socket Wrench
    10mm Socket
    17mm Socket
    Phillps Head Screwdriver
    Flat Head Screwdriver
    Pliers
    So first off go and unplug your battery.
    Then remove your seat, there is a bolt in the space between that and the back part of the seat, that may be a 12mm or 14mm, in my case that bolt was already removed, then tilt the seat towards you and pull, then it should look something like this.
    Now there are 4 screws that's holding the plate down to car, remove those and the plate to the side, then it should look something like this.
    From the picture above you'll see the Fuel Joint Hose, which is the hose to the left and the hose to the right is called the Fuel Pipe Return Hose. To make things easier on me I detached both of those from the Fuel Pump Assembly. You'll need the 17mm to pull the bolt from the Fuel Joint Hose and the pliers to pull the clamp off the Fuel Pipe Return Hose. Be mindful that there are washers on there. Now you can detach the Fuel Meter and unbolt the Fuel Pump Assembly from the car, which you'll need the 10mm socket to do so, as shown below.
    You'll have to maneuver it around because it's one big piece. Once you've completed that it should look something like this.
    You'll now have the whole Fuel Pump Assembly in your hand, and here comes the tricky part.
    On the top part of the actual Fuel Pump is a hose connected by 2 clamps, pull those out the way and you'll have completed 1/2 of the detaching the top, now look and the harness and you'll see it's easy to pull the male from the female by removing a little secure piece that holds it in. Now make your way to the bottom of the Fuel Pump to the pouch. You can pull the Fuel Pump from the assembly.
    In my case I was installing a Walbro 255 LPH
    To pull the pouch of the old fuel pump and put it on the new on just use the Flat Head to wedge to little clamp off, but do it gently. Once completed just install it. Retrace you steps on putting it all on and you'll be good to go
    San antonio 210
    hell yea man. Every helpful info. I might have to sticky this... +1 when i can...
    Its best to replace the screen/filter on the end of the pump when you replace the pump also.
    BMW 750iL
    Southside
    Yea, at the moment I didn't have one on me
    General Tech Hater
    no offense man, but that is one un-needed how to! lol.
    Southside
    Quote Originally Posted by MidLifeCrisis
    lol hey none taken, but seeing that it is for this section and that I've searched and didn't see it anywhere, and again that most of the guys that I know that are in here don't really know how to do it, I felt like sharing my knowledge, like how you desired to share your opinion which didn't bother me any, but felt like it was unneeded as well
    Cobb County
    Quote Originally Posted by JDM_EK4
    Lol, nice write up man! I sure didn't know what to do with this shiit!
    General Tech Hater
    damn! snappy!
    haha, sorry man just saying, kind of anodd how-to.. could probably use some more technical how tos then a fuel pump.. its almost self explanatory..
    maybe we can get a whole FAQ section going like on honda-tech..
    Southside
    damn! snappy!
    lol yea I know. I've searched H-T and even a few EJ1 websites, using good terminology and everything. Nothing came up, this was the one that I felt was most informative, but as you can see nothing on installing fuel pump. http://honda-tech.com/zerothread?id=642479
    The way how it mostly goes, even on H-T, search it before you ask about it, or basically do your research. In this case I did and got short handed, which led me to making this for my friends in here
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Wow that a hell of a lot easier than my car was.
    I wish I didn't have to drop my tank that was a pain in the a$$.
    Southside
    Did tree's really helpful..... Thanx dude nice write up lulz
    Southside
    For everyone with and EJ-EG
    PURP-a-trader PURP's Avatar
    wow... I did 3 of these in the last 2 days... fuck fuel pumps and main relays and everything having to relate to the fuel system...
