Thread: NEED HELP!!
    Senior Member AMD_Civic's Avatar
    Default NEED HELP!!
    SO HERES THE STORY..
    I WAS PUTTIN MY FRONT LIP ON AND SO I HAD THE KEY ON TO TURN THE STEERING WHEEL... AND WHILE I WAS TURNING THE STEERING WHEEL RIGHT I JUST HEARD A THUMP AND NOW I CAN'T EVEN TURN RIGHT NO MORE.. THE STEERING WHEEL WILL GO BUT THEN THE WHEELS WON'T TURN AND I JUST KEEP HEARING THAT THUMP NOISE EVERYTIME I TRY..?? YOU GUYS KNOW WHATS THE PROBLEM??
    turbos
    I think u broke somethin, follow the thump and find out where its comming from
    TOO BIG
    Quote Originally Posted by seanrg1116
    pretty much thats all u have to do.
    Certified Gearhead wwli's Avatar
    Check the U-joint, sounds like something came loose or you broke something.
    Remember it's good that you broke it now when the car is not moving instead of finding out when your on the road driving.
    axle joint probably popped out of place from inside the boot? and it is jammed prolly
    /Oo ___A___ oO\
    |=_/_______\_=|
    iono need to really look at it tommoro..!!
    Don Mon SiRed94's Avatar
    Morrow 30260
    Sounds like a tie-rod issue. Probably the inner.
    thats what one of my buddies told me also, but then i took at the motor and told a buddy to turn the steering wheel and it sounds like my steering column, where the splines connect to the rack and pinion is fukced up.. so question everyone do you know if an 94+ integra would go on and fit mine??
