Thread: SOHC vtec head swap
    All Motor EK N/A EK's Avatar
    On IA.com
    Exclamation SOHC vtec head swap
    OK I searched thru H-T but I couldnt find enough info.
    I have a stock d16y7 in my car right now. I have a p08-3 sohc vtec head w/ p32-ipt2 manifold just sitting at the house. So I thought about swapping the head to my motor. So my question is, what is all needed to do the swap. Searching thru h-t all I see is y7 motors with y8 heads.
    I might also have a p2p ecu @ the house and a obd2 intake manifold. I know that I need to re-wire the vtec solinoid n the icav. But my question is, do I need any additional parts.
    Let me know guys,
    Thanks
    IA Member wanksta's Avatar
    powder springs, GA
    should need the same things as y8 that you found already
    On IA.com
    But see my question is, can I use a obd2 intake manifold(y8) on the po8-3 head w/ the p2p ecu?
    roberta
    just gaskets and stuff...dont forget to pull the oil jet cause if you dont you wont have any vtakkkk!
    powder springs, GA
    should be able to
    turbos
    http://www.d-series.org
    for all of you d-series needs
    /thread
    TOO BIG
