Results 1 to 18 of 18
Thread: crx brake upgrade question
    PWN
    Default crx brake upgrade question
    I need to know if a brake setup from an integra will fit a crx directly or not. Does anyone with a crx know this for sure? Thanks in advance
    Yo mama
    1st try to bleed the brakes properly, then if that doesn't work get another master cylinder (91 Civic EX is best). Check for leaks too.
    If you want to swap brake components: for the rear keep EF control arm, trailing arm is same on DA/DC and find rear discs from a DA. For the front use DA front knuckles and brakes, & since your CRX is not an Si I believe the axles won't go into the DA knuckles either (not 100% sure about that).
    Depends on the car.
    Quote Originally Posted by KevinT707
    how would you know, you didn't do the conversion yet assuming you thinking of doing it yourself aintcha partna,
    FULL disc brakes FTW
    by the way your sig is whackkk
    /Oo ___A___ oO\
    |=_/_______\_=|
    PWN
    can i get someone that has already done the conversion. need some insight
    Yo mama
    It will fit if your using 90-93 integra. The front tires will stick out if you use the front hub. For the rear make sure you get the e brake cable, and brake line other than that it bolts up. Change out your master cylinder from 90-91 honda civic ex model.
    Woah there thats not good information lol. If his CRX is a Si or DX, he can use the full DA front knuckles no prob (just get an alignment). I recommend to swap the rear disc onto his stock trailing arms, DA trailing arms cause the rear wheels to move outward approx 1/2". Ive done several of these conversions!
    Dude i done these too. I just got done with a customer crx hf with da rear disc conversion, he has no problem with it. Been in the game for awhile. These day there is alot of people that know alot of info but don't have the experience doing the work.
    PWN
    so DC integra front and rear wont work on a crx dx? Only DA brakes work?
    Yo mama
    You are claiming that the front tires will stick out with DA hubs. That's simply not true. The DA rear trailing arms most certainly DO change the rear wheel geometry. If you'd like to compare experience and credentials, that's fine too. Ive got more than my reputation on here. I have personally had to roll fenders after installing rear DA trailing arms and also have alignment measurements from a Laser Hunter alignment rack that indicate they changed the width of the rear wheel base.
    i'm claiming the tires, if i didn't make myself clear than sorry. ok i'm not gonna sit here and argue.
    Da knuckles/hubs dont change the wheel positions though aside from a slight caster/camber change. they dont really affect the width of the front wheelbase.
    PWN
    can you answer this "so DC integra front and rear wont work on a crx dx? Only DA brakes work?"
    Yo mama
    Quote Originally Posted by phuoc_dat
    But why if you know that DA brakes will bolt-up just fine, it's been tried many times.
    PWN
    da parts are older and hard to find. haah
    Yo mama
    Southside of The Jungle
    GTFO Da parts are easy to find go to any junkyard man!And if you really balling go to autozone or any auto part store and order parts brand new.... I've got Da brakes all the way around Full disc FTW!Even tho I hate how many sets of 13''s I have found for the low low....
    chill six7teen's Avatar
    Columbus
    i know for a fact that DC rear discs will work.. just keep your stock control arm and ebrake cable..
    PWN
    anyone else second sixteen?
    Yo mama
