Results 1 to 19 of 19
Thread: For those w/ HIDs, etc.
    Default For those w/ HIDs, etc.
    was there ever an issue when u turn on ur signals that ur HIDs/headlights flicker? i have this slight issue, sometimes w/ my maxima (not retrofitted, just installed the kit) and it flickers when i use my signal light. i've spoke to a friend, he says he's never encountered this problem w/ his integra, so i'm kinda thinking a ground kit would solve the issue
    Senior Member G.C's Avatar
    Forgot
    Make sure its not your ballast/bulbs first. Put on your stock halogen bulb that you had and see if it does the same. If it does, most likely your ballast is bad. If not check your wiring for ground and 12v.
    :idb:
    MINE IS PLUG AND PLAY SO AS FAR AS GROUND AND 12V SITUATION, THAT PART DOESN APPLY..BUT ILL TRY WHAT U SAID. THANKS
    Certified Gearhead Silvrmaxx's Avatar
    G-nett
    havent had that problem with my HID's in my max... only problem i have had is if the headlights are on, the car doesnt shut off until the headlights are turned off... just noticed that recently... but in your case, id check the bulb and ballast first... i have replaced a bulb and ballast due to flickering.
    Shift_Clean
    how would i determine whether its teh bulb or ballast from just using my old h4 bulbs?
    G-nett
    do both headlights do it at the same time or is it just one side?
    Shift_Clean
    i wana say teh driver side..but i'm not sure, ill try to pay attention next time it happens
    G-nett
    if its only one side, then i would start by switching the bulbs first. then if it still dows it on that side, you'll know its the ballast. and if it changes sides, then you'll know its the bulb... thats how i figured out my issue with bulbs/ballasts....
    Shift_Clean
    are you using a relay harness? if not thats what i would reccomend..
    no just plugs into the ballast and headlights...
    thanks silvrmaxx
    ALL CAPS JITB's Avatar
    you might want to upgrade your fuse for yoru lights!
    didnt think about that...thanks for an option
    JDM TYTE AnthonyF's Avatar
    No sir. Mine work like a charm...must be your mechanic...
    -Ant.
    The Carbon Fibered R6
    well that means i must fire u
    Hwy 315
    ...cheap ballasts perhaps?
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    its possible...xentec....everything warms up good and all...u can hear it buzz and what not sometimes
    G-nett
    last time i had to replace a ballast i heard it buzzing... not sure if that means its bad or not, but i have replaced a few for others and from the ones i have seen, they were buzzing when they went bad... could they have possibly gotten wet at all?
    Shift_Clean
    where they are its a high possibility
    but the installation said make sure to instal tehm where tehy have good air...so they are right above the splash guard..but should still get good air....
    OK...BOTH LIGHTS FLICKER (HIDS STILL INSTALLED)...SO...WHATS MUH DIAGNOSIS?
