Results 1 to 2 of 2
Thread: alpine type X speakers for sale....
    is doin you
    buford
    Arrow alpine type X speakers for sale....
    ok so i have had these in my car for about 2 weeks.;.sound great but i just need some money..soo here they aer for sale...they are 6 1/2 and im ONLY SELLING THE SPEAKERS
    PRICE IS $150 or 100 plus your speakers depending wut they are
    404-895-2043
    Power Handling
    • CEA-2031 Power Rating: 100 Watts
    • Power Handling Capacity (RMS): 100 Watts
    • Power Handling Capacity (Peak): 300 Watts
    Woofer
    • Dustcap Detail: Machined Aluminum Phase Plug with Direct Heat Transfer Heat-Sink
    • Cone Material: Hybrid Cross-Rib Glass Fiber Cone
    • Motor Technology: Heat Transfer Motor/Frame Coupling
    • Voice Coil Type: High Temp VC CCAW Wire on 39mm Aluminum Former
    • Cooling: Airflow Management
    • Magnet: High Grade Neodymium Magnet
    • Mounting: Shallow Mounting Design
    • Frame: Machined Low-Carbon Steel U-Yoke
    Crossover Network
    • Grade: Audiophile / Expert Grade Network
    • Case Design: Audiophile Layout
    • Attenuation Control: 4 - Level
    • Mounting: Easy-Mount Screw Terminals
    Dimensions
    • Woofer Diameter (mm): 153mm
    • Woofer Diameter (in): 6''
    • Woofer Mounting Diameter (mm): 134mm
    • Woofer Mounting Diameter (in): 5-9/32''
    • Woofer Mounting Depth (mm): 64mm
    • Woofer Mounting Depth (in): 2-1/2''
    • Crossover Size (mm): 112mm x 162mm 32mm
    • Crossover Size (in): 4-13/32'' x 6-3/7'' x 1-1/4''
    General
    • Frequency Response: 35Hz - 60kHz
    • Impedence: 4 Ohms
    • Sensitivity: 88dB /W(1m)
    Attached Thumbnails Attached Thumbnails -1024081718-jpg   -downsized_1024081718a-jpg
    is doin you
    buford
    ttt
