Thread: NEEED HELP ON MY VR6
    Rome,Ga
    Default NEEED HELP ON MY VR6
    for some reason my car not firing people tellin me its the alarm let me know it my dd..
    North Augusta, SC
    Need more info... What IS it doing? Did you change anything recently? Any lights? How's it acting when you try to fire it up?
    Back to being stock and slow
    Rome,Ga
    is a 96 jetta vr6 in its fires for a sec or so then it wont fire agian i reset the alarm try cranking it in it will do the same thing but after that it wont even fire until u reset the alarm??? i replaced a fuel pump but its working correctly.
    alarm is disabling fuel pump. did you mess with any wiring? you may have pulled a connection loose.
    Rome,Ga
    the fuel pump is pumping every once in a while it will crank in run for like 5 sec then die?? idk like it not firing
    ATL, GA
    ooo good luck with that
    I wouldn't know where to start looking for that answer...
    Bunny Colvin's Hamsterdam
    Quote Originally Posted by NissanTun3r
    The VW Vortex VR6 engine forum might be a good place to start. And if you don't have the Bentley manual... get one... they really help out a lot. Bentley (Bentley publishing, that is) manuals are the ones the dealership tech use. You can find 'em on Amazon for about $40.
    VR6 forum:
    http://forums.vwvortex.com/zeroforum?id=29
    Bentley Manual:
    And are you not getting spark or are you not getting fuel? Does your engine have a distributor or individual coilpacks?
    Rome,Ga
    individual coilpacks i had the car runnin the other day then i set the alarm in try crannkin it in would not crank gettin fuel no spark. i think the alarm deativated the igntion system??
