Results 1 to 29 of 29
Thread: D series Gude head and Z6 long block
    Wasting Fossil Fuels n2daizo123's Avatar
    Default D series Gude head and Z6 long block
    Gude head package and Z6 long block $600.
    Single cam vtec. For more info contact Tristan at 770-547-3280.
    1. Intake ports are ported to create maximum velocity then rough cross hatched to provide better fuel atomization, which increases combustion efficiency providing increased power both at low and high rpm.
    2. Exhaust ports are ported to relive internal pressure quickly, yet provide enough velocity to scavenge well, insuring a full fresh fuel and air charge will be delivered to the combustion chambers, not diluted down with left over spent gases from the last firing.
    3. Head surface is milled them hand lapped to create a multi directional #32 micro Finish surface, this leaving hundreds of micro ridges to be crushed down by the steel gasket forming a super micro barrier for better gasket sealing.
    4. Intake to head ports are purposely mismatched or stepped to fight unwanted reverberation and to reduce boundary layer effects improving port flow.
    5. Valve seats we have tried 3 angles so called 5 angle, and many other valve and seat combinations, we have found that the factory angle on the valve is overall the best and that the blended radius parabolic valve seats pioneered by Gude performance provides the most horse power and longevity on most Imports.
    6. Valve guides in most cases we have found that shorting the valve guide is helpful and will promote increased flow while still maintaining excellent valve control.
    7. Valve springs Gude performance camshafts are designed to operate to extreme rpm on stock valve springs, we spent countless hours designing and developing profile which will not require a high pressure valve spring which can cause added friction and valve stem failure due to the high loading of stiffer springs vale stem failure will usually cause major engine damage.
    A few exceptions we will up the spring pressure 8000 rpm.
    8. Camshafts Gude performance Bullfrog or Stinger cams are ground to precise tolerances, and are of the famous Gude profiles. Gude poured out all 30 plus years of experience, into designing cam profiles that are stable at extreme high rpm with stock or light valve spring loading, this increasing horse power and engine reliability, as high valve spring loading can case excessive wear and result in total valve stem failure destroying a expensive engine see article on this site.
    9. THROTTLE BODIES Gude throttle bodies are bored and a new oversize butterfly is installed, this providing maximum flow and performance, with Gudes 20 years of throttle bodie experience Gude has developed a unique aerodynamic shape of the throttle bodie inlet barrel this not only improves flow but also throttle response this make for a great circle track, road race, or autocross throttle bodie, as well as drag racing.
    Z6 long block out of a 95 civic hatch, running when pulled 160k.
    comes with a y8 manifold and throttle body extra.
    Senior Member kaotickaozpunk's Avatar
    nice...repped
    DA SQUAD # 13
    ill give you ipod touch plus cash
    you dont need to know
    do u got any better pics or the in take runners and intake on the head . looks like it was done at home.
    f*ck off
    and has these head ever been used
    f*ck off
    Quote Originally Posted by hondachick22
    i have the reciepts to prove that this wasnt done at home. I dont have better pics because the lighting and flash and they have never been used.
    ttt
    ill trade you a b16 head for it
    f*ck off
    Dont have a need for a b16 head.
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    why arent you using it?this would fit the sohc zc as well? would you be willing to ship it?
    Senior Member WalkS's Avatar
    Middle Ga
    Dang where were you about 6 months ago! Great deal!
    JJSPEC Racing
    I <3 Fat Chicks Farrow2005's Avatar
    Columbus
    imma add that to my wish list.
    Quote Originally Posted by admin
    lets compare bush to jesus i mean they are like best friends
    www.street-706.tk
    ttt
    bump added parts and package deal.
    Middle Ga
    Take any trades?
    Quote Originally Posted by JDMBrian
    Take any trades?
    Nah, got out of cars all i got is my truck.
    not bad man!
    If you called about the parts and left a voice mail i need you to call again as you didnt leave me your number. Thanks.
    who knows.
    i would get the head if it were y8 but z6 boo. good luck with the sale.
    The gude head isnt installed on the motor.
    IA MEMBER jvillagran2000's Avatar
    EVERYWHERE!!!
    Quote Originally Posted by n2daizo123
    it might be just me but this thread is confusing.Your selling to things on this thread right!One is the gude built z6 head and the other is the z6 long block and you want how much for each?
    Quote Originally Posted by jvillagran2000
    You are correct, i have a complete long block and a built z6 gude head. Its $600 for both.
    EVERYWHERE!!!
    how much for just the z6 long block?
    $200 for just the long block.
    ttt
    EVERYWHERE!!!
    pm sent
    EVERYWHERE!!!
    Hey I'll take the long block lmk when I can get it
    The crack
    What all comes with the longblock? I don't need the IM or TB
    Where Am I
    Quote Originally Posted by thinkskater
    x2 good luck, looks like a good deal ....
