Results 1 to 14 of 14
Thread: lowering spring question
    Need Parts!
    Canton
    Default lowering spring question
    ok i have some neuspeed lowering springs (race 55.20.r14) and i want to know if the long spring goes in the front or the back. they were on my friends car and his sat at a good stance then when i put them on i was about 3 inches off the ground. any help plz
    Senior Member G.C's Avatar
    Forgot
    Throws rock
    :idb:
    Smyrna
    The taller one is typically for the rear end.
    Need Parts!
    Canton
    ok so any reason that there is such a difference?
    Smyrna
    The one in the back is usually longer to give the rear suspension more travel.
    roberta
    long ones go in the front....somewhere on the spring the should be a F meanin the front and a R for rear...but pretty sure its the longer ones in front.
    Need Parts!
    Canton
    ha just noticed that theres a start b/c my car was way to low reps to both
    Quote Originally Posted by jcs
    roberta
    Quote Originally Posted by EthanR
    yep no prob bro.GL on it all.
    Smyrna
    Sorry about that, I was thinking VW - the springs on the back of the Golf/Jetta/GTI are always longer. lol
    Need Parts!
    Canton
    i thought the same thing but once it came down i figured something wasnt right lol
    long one goes in the FRONT!
    /Oo ___A___ oO\
    |=_/_______\_=|
    :noitacoL
    probably because the end with the engine is usually heavier than the end without an engine.
    engines are pretty freakin heavy.
    i just installed a set of spring in my hatch.. The taller spring in front ,
    Monore/Atlanta GA
    Taller in the front, I just installed mine 2 weeks ago. But really they only fit properly on the correct strut.
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
