Bought an engine from S&W about a month 1/2 ago and got it up and running. Motor runs great and hasn't given me any mechanical problems. Said they did a leakdown test on it and it read 10's all the way across. Never had a compression test done but i'm sure it's within oem range. So far i've only put 121 miles on the motor which according to the paperwork my reciept read means the motor has a total of 119,377 miles on it. Did an oil change on it obviously when the motor was out of the car with mobil1 10-30 and I checked it today to make sure the oil level was still where it should be. Well it was down to the 1st notch on the dipstick. I checked it about 4 times to make sure i wasn't seeing things. What could make the car burn that much oil in 100 miles? I don't notice it smoking when I drive and can't smell anything burning.
On another note I failed my emmissions test because I had a high input coolant temp sensor problem which I fixed and now it has a cylinder 1 and 2 misfire. It smells like it might have an exhaust leak and I can hear it underneath the car. Sounds like it's coming from where it connects to the cat. Would this cause a cylinder misfire due to back pressure or something else. Has new spark plugs and wires if that means anything.
+reps for help
Good luck.
