Thread: Question....
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    Default Question....
    ok so my speedo dosnt work and i dont like not having a tach. but dont like giant aftermarket tachs. and saw some on ebay and was woundering if a crx guage cluster would work? like this one ------->
    Scottish Scotsman's Avatar
    on the road to recovery
    check where it connects to the tranny
    :noitacoL
    JDMJAY knows, he'll even bring his collection over and install one for you
    San Diego, CA
    It may be as simple as the cable slipped out of the back of your cluster, or out of the tranny itself. JUST installing a cluster with a tach doesn't nec mean you'll have a working tach. I went through like three clusters with no luck. Never did find the wiring issue, either...
    JDMadness ==> EvasiveEF9
    Woodstock/Kennesaw
    ^^^^true true ya first i need to find the problem but i still dont like not having a factory tach.
    Hamilton, GA
    88-89 and 90-91 wiring is different I think
    I'm sure the civic-crx wiring is a little different as in the color of the wires
    I know on my old eg it didn't have a tach but still had the tach wire so jus read up on honda-tech is no one on here gives the answer
    San Diego, CA
    Agreed on a factory tach...
    what time is lunch?
    woodstock
    t2ku is totally correct. 88-89 is totally different wiring than 90-91 and even totally different looking.
    I think a crx will work on a sedan. depending on the year sedan I might have one lying around the garage. I parted out a 88 civic with a tach and also a 89 sedan with a tach.
    let me know the year and I might have one.
    Now the only issue might be dealing with the dizzy. It might not have the tach feedback wiring.
    If your speedo is not working also check down at the tranny to make sure the cable is connected. A quick test is hook the cable from the tranny up to a drill motor and see if the speedo works. If the speedo does not work it is the cable.
    Woodstock/Kennesaw
    ok cool thanks rbwdriven ya if you could check that would be great and mine is a 91 civic sedan dx 5spd. ya ill check on the cable tomorrow
