Results 1 to 5 of 5
Thread: d15b question
    2.2 CL
    Default d15b question
    so im considering getting a ef sedan with the stock d15b2 and i was doing a little reading about how the z6 and y8 have a problem with power steering bracket not fitting etc. so i was wondering if anyone has done this d15b sohc vtec swap into a ef and had any similar problems?
    I did, didn't have a problem. But didn't have powesteering as my EF didn't have powersteering...
    2.2 CL
    if i take the power steering out would it be fine? the steering rack wouldnt lock up or anything right? i read in another forum that it would but this is my 3rd w/o it and havent had a problem yet
    No it won't lock up lol. Just plug the holes.
    Don Mon SiRed94's Avatar
    Morrow 30260
    I had a Z6 in my 4dr EF, and kept power steering on it. I used either a B2 or A6 PS bracket and pump. If I remember correctly, you have to drill the hole on the PS bracket that connects to the side mount larger so the bolt can be angled correctly. And place a washer in between the PS bracket and mount bracket. But, I ended up taking it off because I couldn't find a VSS with the PS ports on it at the time, so it felt extremely loose at higher speeds. But you can disconnect it and run it without the pump without any problems to the rack.
