Results 1 to 22 of 22
Thread: WTB: Bad/Grinding Honda/Acura B-series transmissions
    Master of the G2 Integra cardesignz's Avatar
    Cumming/Alpharetta, GA
    Default WTB: Bad/Grinding Honda/Acura B-series transmissions
    I'm looking for YS1 cable trannys (must actually be a YS1 - not an A1, S1, Y1 or J1) and any 94+ hydro trannys. I'm looking to pay between $50 and $100 tops (for $100, it would need to be a complete short geared tranny). Grinding synchros and/or bad bearings are fine. Let me know what you've got.
    Still haven't had anyone want to sell me the right transmissions for the right price. $100 torn up LS trannys and more for completely busted B16's are the only kinds of offers other than several people coming up with 90-91 trannys and calling them YS1's (even bought one before I figured out how to tell them apart without the label on the case... at least it had a genuine Quaife LSD in it).
    UPDATED Here is exactly what I want:
    94-01 LS = $50 (must have a good 5th gear)
    Short geared 92-93 YS1 or any 94-01 short geared = $100 (less if it is missing anything or anything is broken)
    All small spline 90-91 S1, J1, Y1, A1 = DO NOT WANT
    IS300 NEMO's Avatar
    We Fuckin...
    I got an YS1 cable that wouldn't go into 3rd gear
    Quote Originally Posted by NEMOTEN
    Short geared (B16/B17) or long geared (LS/B18)? How much?
    IS300 NEMO's Avatar
    We Fuckin...
    $150 obo
    too much
    bump for some cheap transmissions
    Senior Member oldschoolteg's Avatar
    KSU & Alpharetta/Cumming, GA
    Bump! Where's the cheap broken transmissions???
    - Aaron
    1989 Acura Integra
    1985 Mazda RX-7
    1986 Buick Electra Estate Wagon
    1993 Nissan 240SX
    Southside of The Jungle
    pm sent!!!!
    Thanks for bumping the thread, I was about ready to find it and bump it again.
    IS300 NEMO's Avatar
    We Fuckin...
    i have another cable tranny. i will have to look and see what kind it is.
    I've got a 95 GSR that won't engage reverse. Good for parts or rebuild. LMK $125. Opened it up and i can manually assist reverse to engage. Not sure what it needs, so don't ask. Also it has been sealed back up for immediate shipping to it's new owner. All other gears work but may need rebuild/refreshing.....
    Cool, let me know.
    Quote Originally Posted by civicturbo10
    Hmm... a little on the high side $wise, but some GSR gears would be nice. Where are you located?
    Quote Originally Posted by cardesignz
    Cool, let me know.
    Near perimeter mall. LMK..
    Cool, let me know.
    GSR tranny sold, pending payment....
    abcdefghijklmnopqrst afwfjustin's Avatar
    need an auto tranny that slips into overdrive? 50 bucks for it
    New car:
    95 S14 with RB25DET (stock boost)
    Old car:
    Turbo S2000 400hp/285tq on 9:1 comp & 11psi
    What would I do with an auto tranny? I've got $400 worth of parts to rebuild a transmission and a couple of the wrong transmissions already.
    EE OG Revmaynard's Avatar
    OP, do you repair transmissions? I have a cable YS1 that won't engage 3rd. Reverse is noisy, too.
    Bozzio for president.
    Are you asking if I want the transmission or if I can repair it for you?
    Hey, that was me asking if you can repair it. (Rev had been on my comp.) Or if I can source a replacement, would you be interested in it?
    Q: how can you tell short from long geared?
    Quote Originally Posted by bam-bam
    If someone found me some transmissions, I could probably do one for them along with mine. A full rebuild kit is almost $300 though (bearings, seals, and synchros). I mean, I just finished buying the rest of the tools needed to pull the gears and bearings on one and have the manuals and a mechanics degree, but I'm not working at a shop or anything.
    I do have a long geared YS1 that went into all gears fine that I was going to use the case from and possibly the 5th gear from if I didn't find a 94+ 5th. I might could swap with you + some cash on your part.
    I'd be interested in the YS1 if you're selling, but I'd have to know which gearing it was.
    If you have it in the car, it's pretty obvious due to the RPM's (about a 1000RPM difference between them). I've been told that if it is not in the car, you can turn the input shaft and count how many times the output turns, but I've always been confused as to how that worked. The most exact way is to open it up and count the teeth on the gears and calculate the gear ratios.
    Here's most of the gear ratios:
    http://www.bergeguy.com/gear-ratios.html
    ttt
    ttt
