Results 1 to 5 of 5
Thread: OBD2 ls into a Del SoL ECU help
    95 teggy for parts DaRussian's Avatar
    Default OBD2 ls into a Del SoL ECU help
    Here is what i have: I have a 1994 Del Sol and i am putting a b18b OBD2 LS motor from a (2001 Integra i think) i have both of the ECUs i have a obd2 b18b ECU and i also have the OBD1 LS ecu. Right now i have the OBD2 harness on the motor and it plugs straight up into the Del SOl harness but when i plug the OBD1 LS ECU the car does not start.
    what do i need to do for it to work properly? do i buy the obd2b to obd1 harness or do i switch the engine harnes to OBD1? any help is apreciated. thanks
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    Just leave it OBD-1, All you need is a OBD-1 Alt and Dizzy and your good.. Also use the Harness from the del-sol !!!
    Quote Originally Posted by 1civic
    i dont have the del sol harness, ill be using obd1 ls harness
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    i have a 95 civic, obd1 obviously, and i swapped a obd2 ls motor in, used the obd2 harness, and ran a p75 obd 1 computer, and it started right up. did not have to touch the wiring whatsoever. plugged the obd2 engine harness to the stock plugs by the strut towers and everything worked fine. are you getting spark, no spark, fuel no fuel, is the pump turning on? i need more details...
    98 Acura Integra LS-DD
    ??????????????????-project
