Results 1 to 3 of 3
Thread: FS: 2008 OGM SX150 Pro 12" Pitbike
    Certified Gearhead froggie3kb's Avatar
    Rossville, GA
    Default FS: 2008 OGM SX150 Pro 12" Pitbike
    I've had this bike for a few months now, and just havent gotten to be able to enjoy it as much as i'd like with the way my health has been. And go figure i'm typing this while i'm in the hospital again...
    I've probably put around 5 or so hours on her of actual ride time, she runs great starts up 1st or 2nd kick. It runs like a raped ape, it'll power up 1-3rd gear with me on it pretty much bone stock. This is what they call a "midsize" pitbike because it has a 12" rear wheel, like the kawasaki klx110 and suzuki drz110's.
    Mods i've put on:
    FMF 4.1 full exhaust
    Keihin PE28 (28mm) carb
    Uni filter
    Price - $1800
    If you've ever heard of Pitster Pro, this is pretty much an identical bike aside from a few goodies. Frame/forks/engine/etc are the same, the OGM has a few more billet goodies and an IRK. I can share more details, etc. if you'd like just let me know.
    Here's a couple videos to show you one in action, ones an outdoor vid of a buddy of mine rippin on his and the other is well a vid to show you what the bikes capable of haha...
    http://www.youtube.com/watch?v=cMNPOU_wwZ0
    http://www.youtube.com/watch?v=kr_Z7...eature=related
    Engine:
    OGM 150cc SOHC Air Cooled Horizontal
    (NEW YX 150 type with KLX/DRZ style top end )
    Manual 4 Speed 4 Up Shift Start In Any Gear Transmission
    5 Plate Clutch
    Inner Rotor Kit
    Lightened Oil Slinger
    External Oil Cooler
    26mm MIKUNI Carb
    Dual Stage Air Filter
    Frame:
    Chromoly Cradle Frame
    Removable Sub-Frame
    3 Point Engine Mount
    Suspension:
    DNM Moto Piggy Back Reservoir Coil Over Rear Shock W/15 Setting
    Compression And Rebound Adjustments 900lb Spring
    Aluminum Pro Swing Arm W/Leverage Blocks
    DNM Front Forks W/Compression And Rebound Adjustments
    7" Front And 8" Rear Travel
    Wheels/Tires:
    Front-14" Alloy Wheel/CNC Billet Hub/2.75X14" Innova Tire
    Rear-12" Alloy Wheel/CNC Billet Hub/3.0X12" Innova Tire
    Additional Features:
    Chromoly Foot Peg Mount
    Stainless Steel Foot Pegs
    CNC Alloy Brake Pedal
    CNC Alloy Shift Lever
    1/4 Turn Throttle
    Alloy Chain Guide
    CNC Fuel Cap
    Front & Rear Wave Disc Rotors
    Steel Braided Brake Lines
    32mm Big Bore Exhaust Pipe
    Billet Adjustable Handle Bar Risers
    Stainless Steel Fasteners
    HD 3M Graphics
    Dimensions & Capacities:
    Overall Length 66"
    Wheel Base 47"
    Seat Height 31"
    Dry Weight 142 lbs.
    Ground Clearance 10"
    Fuel Capacity 3 L
    Oil Reservoir .95L
    Senior Member steedracer's Avatar
    winder
    trade for a 98 cr80 with extras?
    villa rica, ga
    looks like a fun lil bike!!
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
