Thread: Speedo problem...
    Certified Gearhead TrickcitykustomsPrez's Avatar
    Blue Ridge, GA...AKA BFE
    Default Speedo problem...
    hey the speedo in my 93 hatch is messed up and has been for a while. when i bought the car it wasn't working so i took the speedo out of my parts car and apparently i lucked up and it was bad to . When im driving it will work fine sometimes and all of a sudden it will shoot up to 100mph and if i dont hit it fast enough it will wrap all the way around and sit under the stop. It is getting worse so i figured id do something about it. Anyone know of anything else it could be than the speedo?
    It is said that something as simple as
    the flutter of a Butterfly's Wing can
    ultimately cause a typhoon halfway
    around the world.
    -Chaos Theory
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    happened to me in my teg its not the actual speed scensor its the harness/ clip jus go to honda parts and get a new clip and splice it into your harness and it will work fine!
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    is it the plug that your talking about? if thats the case ill put the cluster in it with the tach in it. Just gotta do little more wiring.
    Thanks
    around the world.
    -Chaos Theory
    gwinnett
    no the plug that plugs into the speed scensor on the transmission
    ah k thanks ill try that
    around the world.
    -Chaos Theory
    gwinnett
    u fix it?
