Results 1 to 4 of 4
Thread: Dodge Stealth Twin Turbo - Running like caca!
    Savannah
    Default Dodge Stealth Twin Turbo - Running like caca!
    1992 Dodge Stealth Twin Turbo
    32xxx on dodge rebuilt engine
    It is a buddy at works car. Brought it buy the house because he hasnt driven it in almost two weeks and decided to take it to dinner tonight. Fired up fine. Went to drive off and the car falls on its face and starts to buck under a load off of idle. It doesnt do it from 0-5 percent throttle. I have had this problem before and it was almost always the TPS. I did a quick check on all his hoses and reset his ecu and no change. ITs dark and since it is not his daily were not going to tear in to it until tomorrow. I figured there were some 3000gt and stealth nuts on here who could chime in and say that this is a common problem. Anywho.. let me know whats up. Thanks
    JDM TYTE AnthonyF's Avatar
    Go to:
    www.3si.com
    They will further assist you.
    -Ant.
    The Carbon Fibered R6
    Savannah
    been there.. done that.. I am awaiting a response there as well. I did alot of researching and almost all of the cases are plugs and maf. Apparantely none of them have had tps problems. anywho.. tomorrow we are going to clean the maf and replace the plugs and try again.
    oh but some green is in your future.
    There arent many 3g/stealth owners on here. Those use coil packs correct?
    -Ant.
