Results 1 to 15 of 15
Thread: Tuner Lug Removal [Lost Key]
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Default Tuner Lug Removal [Lost Key]
    Guys i have a slight problem on my hands. I have 8 spline tuner lugs on my TL and I seem to have misplaced my key. How would I go about taking these things off? Anyone have an 8 spline key that I can borrow or a tool that I can use to take it off?
    Appreciate the help ahead of times guys.
    decatur
    can you post a pic of the lug?
    Toyota Tech
    Dec 2003
    Claxton, GA
    snap on got a universal lug remover, its got groves on the inside, you hammer it on, then twist it off and it brings lug with it. need new lugs afterwords though
    2010 Scion xB
    go to any tire place and they should have every lug key known to man.
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Quote Originally Posted by Decepticon™
    go to any GOOD tire place and they should have every lug key known to man.
    Fixed
    Save ur engines!
    Turbo-Wired
    East Cobb
    Quote Originally Posted by tdurr
    Fixed
    Even then, it's still wrong. Most places don't carry any of the random-groove ones like what Toyota/Lexus uses. Spline drive is easy though.
    Sep 2004
    Gwinnett County
    Quote Originally Posted by Kaiser
    how do you remove spline drive ones?
    I have 2 diffrent spline drive keys, might be able to help out.
    Monore/Atlanta GA
    Mine stripped before and I used the correct size star bit to replace it. the key they give you for those lugs always strips out anyways. They're cheaply made.
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    Athens/ATL
    I've gotten lucky a few times with a vice grip and some duct tape (to give the vice something to REALLY bite into). g/l!
    Crazed Impressions
    Winston-Salem, NC
    can you also post a pic of your TL?
    --Crazed Impressions
    get a welder and welt a bolt to it, then unbolt it lol
    Sep 2004
    Gwinnett County
    Quote Originally Posted by Hayes21890
    its an old 1996 TL but i'll post pictures once i get my stuff situated
    go to kuaffman tires they always the different keys for the rims and stuff!! theyll get it off
    Turbo-Wired
    East Cobb
    Quote Originally Posted by IndianStig
    At work we have three different spline-drive sockets, and I haven't found anything spline drive that I couldn't remove with one of those.
    If I do, we have a reverse-threaded lock remover. It'll tear the lugnuts up a bit, but it'll get them off. Lugnuts aren't expensive at Autozone, so I can't imagine why there'd be that much worry involved. If you're determined to get them off without hurting them and they don't match up to any spline drive, you can play with some hex-sockets and see if they will work, though you'll have to hand-turn them and go very slowly and carefully.
    The locks like what Toyota/Lexus use where there's a two-piece lugnut with a key-groove cut into it where they mate are TERRIBLE. They tear up like crazy, and even though they look alike, are usually just slightly different enough to tear each other up if it's wrong.
