Results 1 to 15 of 15
Thread: Car hesitates, misfires at idle..wtf
    Fuhgettaboutit. OhMyGodfather's Avatar
    Default Car hesitates, misfires at idle..wtf
    Ok, at idle, my motor misfires every 2 seconds, and when i get on the throttle it consistantly hesitates and almost takes 10 seconds to get to 60mph from a dead stop.
    Check all my plugs and all are grey/tan and dont smell like fuel.
    Check all my wires for damage, none, even swapped them out for a good set, no fix.
    Swapped air filter, and brake cleaner on maf sensor to clean it off.
    Reset my ecu as well.
    Fuel filter is practically new.
    All injectors sound like they are firing normal when i listen with a screwdriver
    I have fuel to all 4 cylinders
    I have spark to all 4 cylinders
    It is a stock, rebuilt KA24DE.
    Idles at 1k.
    Has a half tank of premium from Citgo.
    Anyone have any idea whats going on?
    itakepictures
    changaroopouch
    are the plugs gapped correctly?
    yes, and the o2 sensor was just replaced as well.
    Newnan
    take off your dist. cap and clean it, replace button if it needs...if that doesn't work take off your fuel rail and clean your injectors thoroughly. if it still doesn't fix the problem you sir have an intake leak. O or you have lost compression.
    One Curve At A Time
    Any oil on ur spark plugs? mine was doing that and a gasket was leaking oil on my plugs
    97 DX Civic w/ H22 FS
    Newnan
    o and alot of bad gas has been floating around with the new "shortages" so that new fuel filter is as good as done most likely if you caught some bad gas. I had a problem with mine, the one that was on there was new when I bought the car and I had to replace it soon after because of some bad gas going around im sure.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Check all of the ignition components (mechanical and electrical), do a compression check, and check the TPS. Spraying the MAF sensor with brake cleaner was not a good idea, it can ruin the unit, hopefully it didn't damage it.
    it ran fine for almost a month after i did that though
    timing
    turbos
    timing
    x2
    TOO BIG
    Newnan
    timing doesn't "just jump" like alot of ppl say...sure it happens, but rarely. if the timing belt is very old and worn, then maybe it might.
    Turbo-Wired
    East Cobb
    Usually when people say timing they don't mean anything about the timing belt, they mean the distributor. The adjustment bolts can loosen and the distributor can wiggle after a while. It doesn't happen ~often~ per-se, but it happens often enough.
    Check your egr system, (assuming this is is a stock motor)...
    Quote Originally Posted by TR_Accord
    Quote Originally Posted by Kaiser
    im talking about in general check both takes a few seconds to do so why not.
    Since these are chain motors, they rarely jump unless the hydraulic tensioner fails... but ignition timing still should be checked..
