Results 1 to 3 of 3
Thread: quick question
    IA Member RememberingNever's Avatar
    Cumming, GA
    Exclamation quick question
    amp is bein a bastard...
    i connect everything you know power to battery, audio wire from head unit to amp, speaker wires to subs...but then when i connect the ground wire anywhere, the little green power light on the amp turns off...
    any advice would be greatly appreciated
    "I would never do crack... I would never do a drug named after a part of my own ass, okay?"
    http://www.myspace.com/now_until_forever
    emartu
    Lawrenceville, GA
    where do you have the ground connected??
    have you checked all your fuses (on amp and in-line)??
    when did the problem start and has anything changed since then??
    do you have the remote wire hooked up too?? (just wasn't listed)
    this might be stupid but i'm guessing the sound doesn't work??
    post back or hit me up on AIM and i'm sure we could get it figured out
    Cumming, GA
    ya i found the problem....there was a 1 inch gap in the metal inside the remote wire thought the insulation wasnt ripped...kinda weird...but thanks for the input
