Results 1 to 11 of 11
Thread: Car won't start HELP
    Duluth, GA
    Default Car won't start HELP
    Have a boosted b16 in a 92 civic si...
    been driving fine...then last wednesday it started to not wanna start up.
    I would crank on it a few times and it would normally start.
    but today it just won't start. I replaced the main relay...still won't start
    RECAP: car turns over...and was driving fine yesterday...today the car won't start and i tnever made any weird noices or anythng....just parked it...let it cool down and turned it off....now it won't start...replaced main relay and that's not it.
    UPDATE:
    checked spark and it seems I have none...took out a plug and turned the motor over and it didn't arc...so I'm guessing no spark...so this means bad dizzy???
    check for spark?
    Loganville
    will the car do anything upon turning the switch?
    Ballin' on a Budget
    Duluth, GA
    UPDATE:
    check your coil pack, ignitor, rotor button, dizzt cap.
    quick fix is to borrow a friends dist that is known working dist. if it doesn't work in your car it could be ecu or wiring...assuming you have stock ignition.
    Duluth, GA
    I got stock ignition...do ECUs just go bad like that?
    not usually, but they can. it's usually fuel pump/main relay circuits that go out. you are dealing with 15 y/o electronics.
    try a dist first...hopefully that cures it.
    Love a good V8 Swap fly-n-low's Avatar
    AL
    My Del Sol did something very similar. Mine was the ignition coil inside of the distributor. Back then it was cheaper to replace the whole distributor from Autozone for like $250.00. Lifetime Warranty. Did you notice any oil around or underneath the distributor or on the engine block? That is usally a sign that is is going to go out in due time.
    FS/FT 2000 Integra GSR. 119,xxx All Original.
    PM me if interested!
    Duluth, GA
    Quote Originally Posted by fly-n-low
    come to think of it I think there is oil leaking down the head from about the dizzy area... oh well I'll get back to it tomorrow
    Out in the Boonies
    Could just be your coil. One way to check is to take the dizzy apart and take the heat sheild/cover off the coil. If it is burnt up then most likely that's the problem.
