Results 1 to 16 of 16
Thread: what cams are these
    The names "Skeezy1" Samhonda95's Avatar
    South Ga. (Pelham)
    Default what cams are these
    we have several set of stock b-series vtec cams. i've identified all of them except 1 set. ive looked all over. they aren't on this site
    http://www.jdmuniverse.com/forums/ho...vtec-cams.html
    or this one
    www.ff-squad.com/tech/temp/VtecCams.htm
    here they are
    Augusta Ga
    they look like b17 cams to me ??
    93 sol Si
    95 sol S
    95 sol Si
    South Ga. (Pelham)
    if you look at the b17's they have 2 small grooves. these have 1
    Southside of The Jungle
    If it aint aftermarket who cares?
    South Ga. (Pelham)
    for an all oem built..........i want to know
    SO....GTFO!
    Oem built ..... you GTFO
    South Ga. (Pelham)
    gsr block
    gsr rods w/arp bolt
    .20 ctr pistons
    ported b16 head
    00 itr cams
    itr intake manny
    itr throttle body
    itr header
    itr flywheel
    92-93 cable gsr tranny
    in a 91 ef hatch
    less than 1500 to build (since i have most of this stuff) and i think it will make nice power and be fun
    Quote Originally Posted by Samhonda95
    gsr block
    gsr rods w/arp bolt
    .20 ctr pistons
    ported b16 head
    00 itr cams
    itr intake manny
    itr throttle body
    itr header
    itr flywheel
    in a 91 ef hatch
    Hope you plan on running on race gas, because ctrs in a gsr is going to yield close to like 13s compression wise.And I dont think 93 will hold that with out risk of detonation
    gsr block
    gsr rods w/arp bolt
    .20 ctr pistons
    ported b16 head
    00 itr cams
    itr intake manny
    itr throttle body
    itr header
    itr flywheel
    in a 91 ef hatch
    itll blow up with CTR pistons in it, id ditch them an get PR3s
    South Ga. (Pelham)
    i'm not useing a gsr head so it wont be that high.
    i've built 2 ls/vtec motors with ctr's and they are fine! 1 made 189whp with a stock b16 head.
    NOW back to the subject.....what cams are these?
    or p30
    South Ga. (Pelham)
    ok.....i wont use ctr's
    so can anyone tell me about these cams
    Only real way is to compare lobes if you dont know
    Out in the Boonies
    x2 ... micrometer is the only way to be 100% sure.
    jun 4's
    South Ga. (Pelham)
    Quote Originally Posted by smote
    jun 4's
    yeah i forgot i bought some......
