Results 1 to 14 of 14
Thread: eclipse transmission problem
    barrow county
    Default eclipse transmission problem
    i drive a 2000 eclipse gt v6 3.0. it started off when i was heading home from school and i hit a little bump (crossing over another road) and i felt a little kick. (it felt as if i didn't balance gas and clutch evenly) and than my transmission went out (feels like when your clutch is out). pushed it into a parking lot and popped the hood. everything looks normal (no leek or anything) than turned the car off, waited about 2 min and i looked under the car, there was a small puddle of (what smell like transmission oil) oil laying right under the transmission and engine. called the tow truck and towed it home. (while on the tow truck, the oil started dripping a lot)
    i asked some people at work and they think its probably the rear main seal that cracked or popped lose.
    if the transmission it self is about to go out, wouldn't you hear some grinding nose or clicking nose as if the teeth in the transmission were slipping over each other?
    i didn't hear anything, the transmission just stop working
    anyone have any ideas? reps for help
    Woodstock
    Just to warn you prepare for some ricer comments
    barrow county
    Quote Originally Posted by Slomaro Z28
    i don't care it just what they think i can care less
    GMS1 cobalt9123's Avatar
    Winder, GA
    first off, don't look at the engine if you're having a transmission problem. Look at the transmission.
    And transmission oil? no.
    I think your tranny is just old and worn as hell from WOT. You probably need a new one or atleast a new clutch from what I hear.
    I'll whistle while you whine.
    2009 Summit White SS/TC
    Senior Member anothaRRR's Avatar
    Gainesville, Ga
    LMAO, I thought about saying something but held myself back....
    It may be possible that a axle popped out and caused the tranny to leak, hard to say really w/o looking underneath it....
    i dont know, fonzy can get gangsta, he drives a impala. hes a wife beater and a shotgun away from being Scarface
    barrow county
    Quote Originally Posted by cobalt9123
    you can see the transmission from hood view... i dont think its the tranny because heard no grinding..
    shouldnt be the clutch cause changed it less than 4k ago
    barrow county
    Quote Originally Posted by anothaRRR
    yea thats what my manager said, the right axle does look a little oily
    Winder, GA
    Quote Originally Posted by eclipse_boy
    Yeah but it'd be extremely hard to see a transmission problem looking down on it seeing as fluids would go out the bottom or side.
    try looking into the axle then.
    What clutch did you put in?
    barrow county
    i put in stock clutch, forgot the name order from O'Reilly
    Woodstock
    Should've gotten a 2G GS-T or TSI, you'd have alot more help
    barrow county
    too many of them thats why i got 3g, but thanks for the ideas guy reps for yall
    Oct 2008
    Athens, Ga
    did you check the clutch master cylinder?
    barrow county
    Quote Originally Posted by BMWMONSTA
    i found out what was the problem, my right axle broke and transmission fluids leaked out. should have known cause the more the wheels turned(push the car) the more fluids leaked
    YR88 Win! Romeo's Avatar
    Middle Ga.
    idk much about 3g's but i was gonna say check the slave cylinder because on teh 2g's its pretty low on the trans. but at least its fixed.
