Thread: power window conv
    roberta
    Default power window conv
    so i did a power window conversion on the hatch from a spare ex i had layin around.did the doors the floor harness and everything.so last week my windows stopped working,the mirrors and everything still work.i replaced the fuses and the relay.does anyone know whats wrong?is there another fuse that may run the windows under the dash?? thanks in advance.
    Senior Member G.C's Avatar
    Forgot
    i dont know much but check to see if your getting any voltage first.
    :idb:
    roberta
    Quote Originally Posted by G.C
    thanks will do.+2
    roberta
    roberta
    got it fixed
    good deal!
    Norcross
    im kinda interested in this. wat all do u need to convert?
    Certified Gearhead neon_ert3's Avatar
    <--- interested too
    ridin in a honda
    barrow county
    Quote Originally Posted by j0nbunklah0m
    he jdm converted vtec to his windows
    Forgot
    so what was the problem?
    :idb:
    roberta
    well i was thinking on doing a write up but not sure yet.basically you need the ex doors,or the panels and all the guts.you replace the old doors with the new there is a whole group of wires that run from the driver side door to the back of the fuse box under the dash.you will also need the floor harness to run power to the other side.put the four fuses in the correct spot and install the power window relay.then bam power doors. if someone tell me where to do a write up id be more than happy
    roberta
    stupid fuse for the wipers and p/w and shit.
