- WTB pistons
WTB pistons
JE pistons for LS. around 9:1-10.5:1 compression
- Rep Power
- 0
I have JE 10.5:1 brand new in the box with the rings 350 bucks lmk 770 378-8675 Nick
are they gonna be good for a turbo set up? i was looking for somethign a little lower. but that price is pretty damn good LMK
- Rep Power
- 0
They will work great on nitrous i say they are better for na. I have that and a fully built ls head Crower stage 2 cams, crower valves, springs, ret, has 5 angle valve job and port and polished rode on it for 1,500 miles Cleanest head you ever seen.
Specs on pistons
Piston Set of 4 - GS/LS/RS 1.8L 4cyl DOHC non-VTEC B18B1 - Bore: 81mm / 3.189in - Rings: 1.0/1.2/2.8mm - Oversize: STD - Stroke: 3.504 - Rod Length: 5.394 - Compression Distance: 1.181 - Head CC: 45 - Compression Ratio: 10.5:1 - Dome Volume: 1.8 - Weight: 277grams - Accepts nitrous - Use with piston ring set 135+3029
- Rep Power
- 0
sorry, im gonna need something a little lower on compression
- WTB pistons
- You may not post replies
- You may not edit your posts
Forum Rules
