Results 1 to 13 of 13
Thread: b18a block with gsr head
    The Other White Meat gijoe0720's Avatar
    Trion, Ga
    Default b18a block with gsr head
    Will a b18a block work with a 98 gsr head?
    This will be goin into an OBD II car
    yep
    thats whats known as a ls/vtec i believe
    Trion, Ga
    I know that but I was told that I would have to have an OBDII block cause of the crank angle sensor.
    oh, i just now saw the obdII part you added
    hmmm, thats probably right, damn obdII stuff
    Banned LS2ner's Avatar
    The Face
    ask vteckidd. but i think it should work
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    IT will work if u convert to obd1. bec obd1 ecus dont check for crank angle sensor and use a gsr harness and your cool. you will not pass emissons however. just save the headache and find a obd2 block atlest it wont be over 10years old ya know.
    Trion, Ga
    Someone told me that if I put my OBD II fuel pump on it then it would work
    the differences are that the OBD2 blocks have Crank sensors on the oil pump housing.
    If you get a OBD1 block, and your going to keep your car OBD2 then you need to put an OBD2 oil pump on the OBD1 block.
    if you are converting to OBD1, you dont need to swap the pump out.
    Do you even know where the fuel pump is in your car LOL
    Trion, Ga
    The fuel pump or the oil pump?
    the OIL PUMP
    fuel pump is located in the gas tank
    Trion, Ga
    Well you asked if I knew where the fuel pump was at. I know you got to take the back seat out to get to it.
    The fuel pump is on the block right? I ain't sure I have never saw one so I don't know but I think it is on the block
    Quote Originally Posted by gijoe0720
    ok now im lost
    you say you kow where your fuel pump is , its behind the back seat, but you think it is on the block.
    is your engine block in your backseat? cause if it is, i cant help you man
    Your making this too hard.
    IF YOU ARE GOING TO STAY OBD2, THEN TAKE YOUR OBD2 OIL PUMP AND PUT IT ON YOUR OBD1 BLOCK aka SWITCH IT WITH YOUR OBD1 OIL PUMP.
    IF YOU ARE GOING TO CONVERT YOUR CAR TO OBD1, THEN JUST LEAVE IT THE WAY IT IS.
    OIL PUMP IS LOCATED ON THE TIMING BELT SIDE OF THE MOTOR ON THE END OF THE CRANKSHAFT. IF YOU HAVE NEVER DONE IT BEFORE BUY A HONDA SERVICE MANUAL AND FOLLOW THE INSTRUCTIONS BEFORE YOU BLOW SOMETHING UP.
    hope this helps.
    down the yellow brick road
    LOL I think he meant to say, the OIL pump is on the block.....
