Thread: need help with turn signals
    Oct 2008
    south side...clay-co
    Default need help
    ok i have a 94 hatch and the hazard and turn signals wont work no more i changed the fuses and they still wont work i changed the hazard button 2 and still nothing
    Bulbs?
    Oct 2008
    i changed the bulbs all the lights come on.......but wen i push the hazrd light it doesnt even show it on the cluster neither wen i put the turn signal it doesnt make the noise and doesnt show the flashing on the cluster.......any more advice
    Turbo-Wired
    East Cobb
    It's most likely the flasher unit itself, or the relay. Both of which are in your steering column. Pick up a Haynes or other manual for your civic if you don't already have one and locate it, should be an easy replace.
    JDM TYTE AnthonyF's Avatar
    I agree with Kaiser. The flasher relay could be bad. I replaced on on my civic, real easy to do and cheap.
    -Ant.
    The Carbon Fibered R6
    It's all about JDM.
    CA to GA
    use a volt meter, and start testing wires...test the slots where fuses plug in too..
    Oct 2008
    thanks guys i fixed it......it was my fuse box
