Results 1 to 10 of 10
Thread: Thinking about sprayin...
    VTECKLR amped4life33's Avatar
    Rome Ga
    Default Thinking about sprayin...
    I found a Zex kit for a good price for my mostly stock mustang and I was thinkin about puttin a small shot on it. i dont think id spray more than 75 or 100 but i wanna know if its a bad idea or not...i mean im basically stock except for intake/tune/exhaust...Its a 2006 281 by the way...does anyone else do this or have any experience with it, or know if its a bad idea or not?
    **Original photo by CF Photography**
    Dry or Wet?
    Rome Ga
    well the one i found is wet..but i dont have a really good understanding of the difference...
    I don't feel like typing so
    Q: What is the difference between a "wet" nitrous kit and a "dry" nitrous kit?
    A: A wet nitrous kit mixes nitrous and enrichment fuel by means of an injector nozzle that is mounted before the throttle body. This mixture is then drawn into the engine through the throttle body and intake manifold. A "dry" nitrous kit injects only nitrous with it’s injector while at the same time, increasing the engine’s fuel rail pressure to feed enrichment fuel through the engine’s own injectors.
    Rome Ga
    so is one particularly better than the other...or is one safer than the other or maybe better on the engine? or does on have a power perk? i guess what im asking is what are the ups and downs of each?
    Q: What is better, a "wet" or "dry" kit?
    A: It all depends on the application. A "wet" kit is ideal for both normally aspirated applications as well as forced induction applications. It can require a little bit more installation time than a "dry" kit, but is easier to tune if greater than stock HP settings are to be experimented with. A "dry" kit is excellent for normally aspirated combinations that have a return style fuel system. They are very easy to install and are a great "first time" nitrous system. It is not recommended that "dry" systems be used on forced induction engines.
    IA's Pedo-cord tdurr's Avatar
    Fayco
    ^^ reps to u both, i never knew the diff...
    Save ur engines!
    1010011010 Atlblkz06's Avatar
    Hell
    All it takes is a simple google, you don't have to wait for people to feed you the answers!
    With a dry nitrous kit you can have uneven distribution that can lead to bad situations. This happens because the jet is usualy int he intake. However the wet kits have a more distrubuted spray and are more even.
    Go wet!
    BB2 Danzo's Avatar
    The Moon Son!1!1!!1
    Ooooh yea I like it wet haha. But yea wet all the way I would say if you do decide to get into it. Btw I still want to drive you car haha. I'll let you drive the sexlude.
    Picture compliments of ~CF Photography~
    530TQ + FWD = FAIL!! Kason23's Avatar
    Rockmart
    Yep wet is the way to go keeps things safer IMO. Or even better direct port FTW!!!!
    Neon PoWa
    Now Delta 46 equipped
    432whp/425wtq on lower boost
